주요 콘텐츠로 건너뛰기
HTC One X Plus Motherboard Replacement
필요한 것
  1. HTC One X Plus Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro sim card holder to remove it.
    • The Sim Card Slot is located on the top edge of the device.
  2. HTC One X Plus Motherboard Replacement: 2 단계, 이미지 1/3 HTC One X Plus Motherboard Replacement: 2 단계, 이미지 2/3 HTC One X Plus Motherboard Replacement: 2 단계, 이미지 3/3
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
  3. HTC One X Plus Motherboard Replacement: 3 단계, 이미지 1/3 HTC One X Plus Motherboard Replacement: 3 단계, 이미지 2/3 HTC One X Plus Motherboard Replacement: 3 단계, 이미지 3/3
    • Using a Philips head screw driver, remove the five 2.4mm screws that are pictured. Then remove the plastic cover.
    • Once you have disassembled your device the warranty will no longer be valid.
  4. HTC One X Plus Motherboard Replacement: 4 단계, 이미지 1/3 HTC One X Plus Motherboard Replacement: 4 단계, 이미지 2/3 HTC One X Plus Motherboard Replacement: 4 단계, 이미지 3/3
    • Use the J000 Philips screw driver head to remove the screws as pictured.
    • There are two 3.4mm screws to be removed.
    • Remove the PCB board and the antenna.
  5. HTC One X Plus Motherboard Replacement: 5 단계, 이미지 1/2 HTC One X Plus Motherboard Replacement: 5 단계, 이미지 2/2
    • Using tweezers, disconnect the power button flex cable.
    • Then disconnect the touch screen flex cable.
  6. HTC One X Plus Motherboard Replacement: 6 단계, 이미지 1/3 HTC One X Plus Motherboard Replacement: 6 단계, 이미지 2/3 HTC One X Plus Motherboard Replacement: 6 단계, 이미지 3/3
    • Disconnect the battery from the logic board.
    • Look for a white six pin connector.
    • Remove the battery by pulling upwards.
  7. HTC One X Plus Motherboard Replacement: 7 단계, 이미지 1/1
    • Disconnect the remaining two flex cables following the same procedure from Step 5.
    • Once these two flex cables have been disconnected, you may now remove the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jason Melo
회원 가입일: 08/26/15
483 평판
안내서 4개 작성하였습니다
USF Tampa, Team 3-3, Eyestone Fall 2015 USF Tampa, Team 3-3, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S3G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 1,235
