주요 콘텐츠로 건너뛰기
HTC One X Plus Screen Replacement
필요한 것
  1. HTC One X Plus Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal in the hole next to the micro sim card holder to remove it.
    • The sim card slot is located on the top edge of the device.
  2. HTC One X Plus Screen Replacement: 2 단계, 이미지 1/3 HTC One X Plus Screen Replacement: 2 단계, 이미지 2/3 HTC One X Plus Screen Replacement: 2 단계, 이미지 3/3
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
  3. HTC One X Plus Screen Replacement: 3 단계, 이미지 1/3 HTC One X Plus Screen Replacement: 3 단계, 이미지 2/3 HTC One X Plus Screen Replacement: 3 단계, 이미지 3/3
    • Remove the five 2.4 mm screws using a Phillips #000 screwdriver.
    • Remove the plastic cover.
  4. HTC One X Plus Screen Replacement: 4 단계, 이미지 1/3 HTC One X Plus Screen Replacement: 4 단계, 이미지 2/3 HTC One X Plus Screen Replacement: 4 단계, 이미지 3/3
    • Use a Phillips #000 screwdriver to remove the two 3.4 mm screws.
    • Remove the PCB board and antenna.
  5. HTC One X Plus Screen Replacement: 5 단계, 이미지 1/2 HTC One X Plus Screen Replacement: 5 단계, 이미지 2/2
    • Use tweezers to disconnect the power button flex cable.
  6. HTC One X Plus Screen Replacement: 6 단계, 이미지 1/3 HTC One X Plus Screen Replacement: 6 단계, 이미지 2/3 HTC One X Plus Screen Replacement: 6 단계, 이미지 3/3
    • Disconnect the battery's six pin connector from the motherboard.
    • Remove the battery by pulling it upwards.
  7. HTC One X Plus Screen Replacement: 7 단계, 이미지 1/1
    • Disconnect the screen from the digitizer.
    • Use a plastic opening tool to gently disconnect the screen from the digitizer.
    • You may have to use heat to loosen adhesive securing the screen.
결론
Jason Melo
회원 가입일: 08/26/15
483 평판
안내서 4개 작성하였습니다
USF Tampa, Team 3-3, Eyestone Fall 2015 USF Tampa, Team 3-3, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S3G3
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
Man, this did nothing but break my International One X+. There were so many instructions missing.
Garrett Reyman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,841
