주요 콘텐츠로 건너뛰기
HTC One X Plus Top Speaker Replacement
필요한 것
  1. HTC One X Plus Top Speaker Replacement, Top Speaker: 1 단계, 이미지 1/1
    • Hold down the power button to turn off your device.
    • Insert a pin, paper clip, or another similar object into the hole next to the micro sim card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
  2. HTC One X Plus Top Speaker Replacement: 2 단계, 이미지 1/3 HTC One X Plus Top Speaker Replacement: 2 단계, 이미지 2/3 HTC One X Plus Top Speaker Replacement: 2 단계, 이미지 3/3
    • Using plastic opening tools, pry open the bottom of the device.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached use the suction cup tool to remove the screen completely from the black casing.
  3. HTC One X Plus Top Speaker Replacement: 3 단계, 이미지 1/3 HTC One X Plus Top Speaker Replacement: 3 단계, 이미지 2/3 HTC One X Plus Top Speaker Replacement: 3 단계, 이미지 3/3
    • Remove the five 2.4mm screws located around the camera using a Philips head screwdriver to remove the plastic cover.
    • Once you have disassembled your device the warranty will no longer be valid.
  4. HTC One X Plus Top Speaker Replacement: 4 단계, 이미지 1/3 HTC One X Plus Top Speaker Replacement: 4 단계, 이미지 2/3 HTC One X Plus Top Speaker Replacement: 4 단계, 이미지 3/3
    • Use the J000 Philips screwdriver to remove the screws and remove the PCB board and antenna.
    • These are two 3.4mm Philips head screws found in the lower right corner of the phone.
  5. HTC One X Plus Top Speaker Replacement: 5 단계, 이미지 1/2 HTC One X Plus Top Speaker Replacement: 5 단계, 이미지 2/2
    • Pull out the power button flex cable using tweezers to disconnect from the phone.
    • Use the tweezers to then disconnect the touch screen flex cable.
  6. HTC One X Plus Top Speaker Replacement: 6 단계, 이미지 1/3 HTC One X Plus Top Speaker Replacement: 6 단계, 이미지 2/3 HTC One X Plus Top Speaker Replacement: 6 단계, 이미지 3/3
    • Remove the battery connections to the logic board.
    • This is the six pin connector seen in the red box.
    • Pull the battery away to remove from the back of the screen.
  7. HTC One X Plus Top Speaker Replacement: 7 단계, 이미지 1/2 HTC One X Plus Top Speaker Replacement: 7 단계, 이미지 2/2
    • CAUTION: carefully remove the top speaker from the phone using tweezers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jason Melo
회원 가입일: 08/26/15
483 평판
안내서 4개 작성하였습니다
USF Tampa, Team 3-3, Eyestone Fall 2015 USF Tampa, Team 3-3, Eyestone Fall 2015 회원
USFT-EYESTONE-F15S3G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 423
