주요 콘텐츠로 건너뛰기
HTC One X SIM Card Tray Replacement
필요한 것
  1. HTC One X SIM Card Tray Replacement, SIM Card Tray: 1 단계, 이미지 1/1
    • Insert a safety pin or other small object in the small opening next to the SIM card slot to remove the SIM card.
    • The Sim Card Slot is located at the top of the rear panel.
  2. HTC One X SIM Card Tray Replacement, Repair SIM card tray: 2 단계, 이미지 1/1
    • Cut a piece of tape/ paper approximately the size of your Sim Card and secure it to the back side of the Sim. Be sure to trim any excess.
    • It's important that you place the tape on the back side of the Sim Card as it will block the communication with the device if placed on the front side
    • Slowly slide the Sim Card tray back into the device. It should be a smooth transition, don't force the tray in.
    • If the tray is still loose you can keep adding tape/paper until it's no longer loose.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Blain Abebe
회원 가입일: 09/22/14
766 평판
안내서 3개 작성하였습니다
USF Tampa, Team 4-3, Brown Fall 2014 USF Tampa, Team 4-3, Brown Fall 2014 회원
USFT-BROWN-F14S4G3
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 11
전체 시간: 6,898
