이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the phone over to have the rear cover facing up.
The camera lens should be towards the top of the phone.
Slide the cover up, towards the top of phone, to unlock the battery cover.
Lift the cover off phone and remove it.
Use your finger to push the top of the battery downwards and lift the battery out of the phone.
이 단계에 사용된 도구:Plastic Cards$2.99-
Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
Pry the motherboard away from the front of the plastic case using a plastic opening tool.
Carefully lift the black lock to release the ribbon cable, using the plastic opening tool.
다른 2명이 해당 안내서를 완성하였습니다.
