주요 콘텐츠로 건너뛰기
HTC Radar 4G Touch Digitizer Replacement
필요한 것
  1. HTC Radar 4G Touch Digitizer Replacement, Touch Digitizer: 1 단계, 이미지 1/2 HTC Radar 4G Touch Digitizer Replacement, Touch Digitizer: 1 단계, 이미지 2/2
    • Slide the lower plastic panel off of the phone.
    • Remove the four screws from the white plastic cover of the phone using the T5 Torx screwdriver.
    • Remove the two black screws from the silver frame.
  2. HTC Radar 4G Touch Digitizer Replacement: 2 단계, 이미지 1/1
    • Remove the back cover by pressing on the back of the motherboard lightly and pulling the screen out carefully.
  3. HTC Radar 4G Touch Digitizer Replacement: 3 단계, 이미지 1/1
    • Remove the battery from the phone using a fingernail or an opening pick.
  4. HTC Radar 4G Touch Digitizer Replacement: 4 단계, 이미지 1/1
    • Remove the three screws using a screwdriver.
    • Remove the plastic frame.
  5. HTC Radar 4G Touch Digitizer Replacement: 5 단계, 이미지 1/3 HTC Radar 4G Touch Digitizer Replacement: 5 단계, 이미지 2/3 HTC Radar 4G Touch Digitizer Replacement: 5 단계, 이미지 3/3
    • Remove the upper board and motherboard from the phone using an opening tool.
    • The regular black nylon spudger should be used whenever possible, especially around motherboards.
  6. HTC Radar 4G Touch Digitizer Replacement: 6 단계, 이미지 1/2 HTC Radar 4G Touch Digitizer Replacement: 6 단계, 이미지 2/2
    • Use your hands to remove the touch digitizer.
결론
Kevin Guerra
회원 가입일: 10/10/16
101 평판
안내서 1개 작성함
Texas Tech, Team 12-5, Bennett Fall 2016 Texas Tech, Team 12-5, Bennett Fall 2016 회원
TTU-BENNETT-F16S12G5
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 13
전체 시간: 287
