소개
This guide will be detailing the steps necessary to fix a number of common issues with the screen of an HTC Rezound. Please keep in mind that the display and the screen of your Rezound may be fuzed. That means that to replace one you'll need to replace both. Other than that, the adhesive tape on the display is tricky, so take your time! Have fun fixing your tech!
  1. Use a plastic opening tool or your fingers to get into the groove between the cover and case. Remove the back covering so that the red battery is  visible.
    • Use a plastic opening tool or your fingers to get into the groove between the cover and case. Remove the back covering so that the red battery is visible.
  2. Remove the red battery to replace.
    • Remove the red battery to replace.
  3. Unscrew the six screws (Torx T4 size) shown in the photo. Use the spudger to pry the casing off of the phone. Use the spudger to pry the casing off of the phone.
    • Unscrew the six screws (Torx T4 size) shown in the photo.
    • Use the spudger to pry the casing off of the phone.
  4. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  5. Gently remove the casing from the phone. Gently remove the casing from the phone.
    • Gently remove the casing from the phone.
  6. After the red casing is removed, the following components should be visible:
    • After the red casing is removed, the following components should be visible:
    • Main Camera
    • Headphone Jack
    • Vibration moter
  7. Remove the 2 screws (Torx T7 size), which are located on the upper left and lower right sides of the device. Remove the 2 screws (Torx T7 size), which are located on the upper left and lower right sides of the device.
    • Remove the 2 screws (Torx T7 size), which are located on the upper left and lower right sides of the device.
  8. Using tweezers, flip the latch on the ribbon cables connecting the logic board to the screen and display. The screen and display for the HTC Rezound are likely fused to one another, so if you are replacing one  you will likely need to replace both of them. At this point all that's left is to insert the ribbon cables of your replacement into the same slot on the motherboard! At this point all that's left is to insert the ribbon cables of your replacement into the same slot on the motherboard!
    • Using tweezers, flip the latch on the ribbon cables connecting the logic board to the screen and display. The screen and display for the HTC Rezound are likely fused to one another, so if you are replacing one you will likely need to replace both of them.
    • At this point all that's left is to insert the ribbon cables of your replacement into the same slot on the motherboard!
결론
Bridgette Mellon
회원 가입일: 2018년 01월 29일
243 평판
안내서 2개 작성하였습니다
University of Alabama, Team S3-G12, Bedsole Spring 2018 University of Alabama, Team S3-G12, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S3G12
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 103
