주요 콘텐츠로 건너뛰기
HTC Rezound Vibration Monitor Replacement
필요한 것
  1. HTC Rezound Vibration Monitor Replacement, Battery: 1 단계, 이미지 1/1
    • Use a plastic opening tool or your fingers to get into the groove between the cover and case. Remove the back covering so that the red battery is visible.
  2. HTC Rezound Vibration Monitor Replacement: 2 단계, 이미지 1/1
    • Remove the red battery to replace.
  3. HTC Rezound Vibration Monitor Replacement, Vibration Monitor: 3 단계, 이미지 1/3 HTC Rezound Vibration Monitor Replacement, Vibration Monitor: 3 단계, 이미지 2/3 HTC Rezound Vibration Monitor Replacement, Vibration Monitor: 3 단계, 이미지 3/3
    • Using a Torx T4 screwdriver, remove the six screws from the six spots shown in the photo.
    • Use a spudger to pry the casing from the phone.
  4. HTC Rezound Vibration Monitor Replacement: 4 단계, 이미지 1/2 HTC Rezound Vibration Monitor Replacement: 4 단계, 이미지 2/2
    • Gently remove casing from phone.
  5. HTC Rezound Vibration Monitor Replacement: 5 단계, 이미지 1/1
    • Shown here is the vibration Monitor, this is what you will be replacing.
  6. HTC Rezound Vibration Monitor Replacement: 6 단계, 이미지 1/3 HTC Rezound Vibration Monitor Replacement: 6 단계, 이미지 2/3 HTC Rezound Vibration Monitor Replacement: 6 단계, 이미지 3/3
    • Remove the body of the monitor from the case attaching it to the motherboard.
    • Make sure to remove any potential obstruction that could be blocking the weight at the end!
  7. HTC Rezound Vibration Monitor Replacement: 7 단계, 이미지 1/1
    • Carefully disconnect the cable attached at the motherboard.
  8. HTC Rezound Vibration Monitor Replacement: 8 단계, 이미지 1/1
    • Insert the replacement's cable into the same spot on the logic board! Then just set it back into the slot on the logic board and you are done!
결론
Robin White
회원 가입일: 01/29/18
133 평판
안내서 1개 작성함
University of Alabama, Team S3-G12, Bedsole Spring 2018 University of Alabama, Team S3-G12, Bedsole Spring 2018 회원
UA-BEDSOLE-S18S3G12
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 4
전체 시간: 123
