주요 콘텐츠로 건너뛰기
HTC Rhyme Speaker Replacement
필요한 것
  1. HTC Rhyme Speaker Replacement, Speaker: 1 단계, 이미지 1/2 HTC Rhyme Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • Slide the bottom back casing off, pulling down.
  2. HTC Rhyme Speaker Replacement: 2 단계, 이미지 1/2 HTC Rhyme Speaker Replacement: 2 단계, 이미지 2/2
    • Using the plastic tool, pry underneath the top plastic cover.
  3. HTC Rhyme Speaker Replacement: 3 단계, 이미지 1/2 HTC Rhyme Speaker Replacement: 3 단계, 이미지 2/2
    • Using a metal spudger, pry up the plastic piece covering the motherboard, and remove the sticker.
  4. HTC Rhyme Speaker Replacement, Removing the Back Plastic Motherboard Cover: 4 단계, 이미지 1/2 HTC Rhyme Speaker Replacement, Removing the Back Plastic Motherboard Cover: 4 단계, 이미지 2/2
    • Use a Philip #0 screwdriver to remove the four screws of the plastic covering the motherboard.
  5. HTC Rhyme Speaker Replacement: 5 단계, 이미지 1/1
    • Using tweezers, remove the yellow ribbon by gently pulling on it.
  6. HTC Rhyme Speaker Replacement: 6 단계, 이미지 1/2 HTC Rhyme Speaker Replacement: 6 단계, 이미지 2/2
    • Using the plastic tweezers, gently lift the blue flaps up.
  7. HTC Rhyme Speaker Replacement: 7 단계, 이미지 1/2 HTC Rhyme Speaker Replacement: 7 단계, 이미지 2/2
    • Using your thumb, push the flap up on the top.
    • Using your thumb, push the flap up on the bottom of the motherboard.
  8. HTC Rhyme Speaker Replacement, Unscrewing the Motherboard: 8 단계, 이미지 1/2 HTC Rhyme Speaker Replacement, Unscrewing the Motherboard: 8 단계, 이미지 2/2
    • Using a Phillips #00 screwdriver, unscrew the four screws in each corner of the motherboard.
  9. HTC Rhyme Speaker Replacement, Removing the Motherboard: 9 단계, 이미지 1/1
    • Carefully remove the motherboard from the base of the phone.
  10. HTC Rhyme Speaker Replacement: 10 단계, 이미지 1/3 HTC Rhyme Speaker Replacement: 10 단계, 이미지 2/3 HTC Rhyme Speaker Replacement: 10 단계, 이미지 3/3
    • Gently push the base of the phone from the frame.
  11. HTC Rhyme Speaker Replacement, Battery Removal: 11 단계, 이미지 1/2 HTC Rhyme Speaker Replacement, Battery Removal: 11 단계, 이미지 2/2
    • Using the metal spudger, remove the battery from the base.
  12. HTC Rhyme Speaker Replacement, Locating and Replacing the Speaker: 12 단계, 이미지 1/2 HTC Rhyme Speaker Replacement, Locating and Replacing the Speaker: 12 단계, 이미지 2/2
    • Using tweezers, lift the secondary motherboard from the base of the phone.
    • The speaker is located on the back of the board.
결론
Kelsey Harris
회원 가입일: 10/08/14
154 평판
안내서 1개 작성함
USF Tampa, Team 9-6, Leahy Fall 2014 USF Tampa, Team 9-6, Leahy Fall 2014 회원
USFT-LEAHY-F14S9G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 333
