주요 콘텐츠로 건너뛰기
HTC Rhyme charging port Replacement
필요한 것
  1. HTC Rhyme charging port Replacement, Charging Port: 1 단계, 이미지 1/2 HTC Rhyme charging port Replacement, Charging Port: 1 단계, 이미지 2/2
    • Image of the front and back of the HTC Rhyme.
  2. HTC Rhyme charging port Replacement: 2 단계, 이미지 1/3 HTC Rhyme charging port Replacement: 2 단계, 이미지 2/3 HTC Rhyme charging port Replacement: 2 단계, 이미지 3/3
    • Remove the back cover by pulling down on the lower half.
  3. HTC Rhyme charging port Replacement: 3 단계, 이미지 1/3 HTC Rhyme charging port Replacement: 3 단계, 이미지 2/3 HTC Rhyme charging port Replacement: 3 단계, 이미지 3/3
    • Use a T5 to remove the five highlighted screws in the image.
  4. HTC Rhyme charging port Replacement: 4 단계, 이미지 1/2 HTC Rhyme charging port Replacement: 4 단계, 이미지 2/2
    • Once the screws are removed, slide the back cover off of the phone.
  5. HTC Rhyme charging port Replacement: 5 단계, 이미지 1/3 HTC Rhyme charging port Replacement: 5 단계, 이미지 2/3 HTC Rhyme charging port Replacement: 5 단계, 이미지 3/3
    • Remove the two screws highlighted in the image with a Phillips screwdriver.
  6. HTC Rhyme charging port Replacement: 6 단계, 이미지 1/2 HTC Rhyme charging port Replacement: 6 단계, 이미지 2/2
    • Push off the small silver piece resting above the charging port.
  7. HTC Rhyme charging port Replacement: 7 단계, 이미지 1/3 HTC Rhyme charging port Replacement: 7 단계, 이미지 2/3 HTC Rhyme charging port Replacement: 7 단계, 이미지 3/3
    • Disconnect the black cable on the upper right side of the motherboard.
  8. HTC Rhyme charging port Replacement: 8 단계, 이미지 1/3 HTC Rhyme charging port Replacement: 8 단계, 이미지 2/3 HTC Rhyme charging port Replacement: 8 단계, 이미지 3/3
    • Disconnect the green cables in the upper center section of the motherboard.
  9. HTC Rhyme charging port Replacement: 9 단계, 이미지 1/3 HTC Rhyme charging port Replacement: 9 단계, 이미지 2/3 HTC Rhyme charging port Replacement: 9 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Disconnect the yellow cable by gently pulling on it with tweezers.
    • When assembling, use your fingers to reconnect the wire.
  10. HTC Rhyme charging port Replacement: 10 단계, 이미지 1/3 HTC Rhyme charging port Replacement: 10 단계, 이미지 2/3 HTC Rhyme charging port Replacement: 10 단계, 이미지 3/3
    • Disconnect the white cord on the lower left side of the motherboard.
  11. HTC Rhyme charging port Replacement: 11 단계, 이미지 1/3 HTC Rhyme charging port Replacement: 11 단계, 이미지 2/3 HTC Rhyme charging port Replacement: 11 단계, 이미지 3/3
    • Gently remove the motherboard with your hand.
  12. HTC Rhyme charging port Replacement: 12 단계, 이미지 1/3 HTC Rhyme charging port Replacement: 12 단계, 이미지 2/3 HTC Rhyme charging port Replacement: 12 단계, 이미지 3/3
    • Desolder and remove the charging port on the motherboard.
    • Solder a new charging port onto the pads where the previous charging port had been.
  13. HTC Rhyme charging port Replacement: 13 단계, 이미지 1/3 HTC Rhyme charging port Replacement: 13 단계, 이미지 2/3 HTC Rhyme charging port Replacement: 13 단계, 이미지 3/3
    • Follow steps 11 through 1, to put the phone back together.
결론
Rebecca Chapman
회원 가입일: 06/01/16
104 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 288
