소개
By taking off the cover, and unscrewing the back of the phone we will reach the motherboard to replace.
The motherboard controls the software of the phone and is an essential piece to any logic process.
부품
지정된 부품이 없습니다.
Insert thumb and pointer finger into the notch above the battery. Pull the battery away from the rest of the phone and set it aside.
To remove the back casing inside the phone, use a small, pentagonal screwdriver to unscrew the 6 screws that can be found around the edges.
Next, unscrew the top screw using a small, Philips screwdriver. You will now be able to pull the motherboard back.
Using a spudger, remove the display screen from its cell within the front case. Insert the spudger next to the LCD on the opposite side of where the motherboard is attached.
다른 한 분이 해당 안내서를 완성하였습니다.
