주요 콘텐츠로 건너뛰기
HTC Surround SD Card Replacement
필요한 것
  1. HTC Surround SD Card Replacement, Back Case: 1 단계, 이미지 1/2 HTC Surround SD Card Replacement, Back Case: 1 단계, 이미지 2/2
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. HTC Surround SD Card Replacement: 2 단계, 이미지 1/3 HTC Surround SD Card Replacement: 2 단계, 이미지 2/3 HTC Surround SD Card Replacement: 2 단계, 이미지 3/3
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. HTC Surround SD Card Replacement: 3 단계, 이미지 1/1
    • Separate the screen and back cover with the opening tool.
  4. HTC Surround SD Card Replacement, SD Card: 4 단계, 이미지 1/3 HTC Surround SD Card Replacement, SD Card: 4 단계, 이미지 2/3 HTC Surround SD Card Replacement, SD Card: 4 단계, 이미지 3/3
    • Look at the bottom right hand corner of the device and remove the silver tape covering the SD card slot with your fingers.
    • Insert the plastic opening tool directly underneath the orange surface below the SIM card until its removed from the surface of the device.
  5. HTC Surround SD Card Replacement: 5 단계, 이미지 1/2 HTC Surround SD Card Replacement: 5 단계, 이미지 2/2
    • To get to the attachment that the SD/SIM card is attached to; insert the plastic opening tool underneath the lower motherboard until it is removed from the bottom half of the device.
    • You will notice the SD/SIM card is attached to the lower motherboard by a yellow piece of tape. Remove the tape from the back of motherboard with your fingers.
결론
Michael Ronning
회원 가입일: 09/21/18
389 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 203
