소개
Use this guide to replace a broken or damaged camera.
부품
지정된 부품이 없습니다.
Insert the plastic opening tool into the top of the Thunderbolt near the power button.
Gently pry up on the rear panel around the edges until it is loose.
Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
Remove the battery from the inner frame.
Using the tip of an plastic opening tool flip up the tab holding the capacitive button ribbon cable.
Use a pair of tweezers to pull the capacitive button cable out of its socket.
Use a finger nail to get in between the tape and the phone, then pull the tape off gently.
다른 한 분이 해당 안내서를 완성하였습니다.
