주요 콘텐츠로 건너뛰기
HTC Thunderbolt MicroSD Card Replacement
필요한 것
  1. HTC Thunderbolt MicroSD Card Replacement, Rear Panel: 1 단계, 이미지 1/1
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. HTC Thunderbolt MicroSD Card Replacement: 2 단계, 이미지 1/1
    • Lift and remove the rear panel.
  3. HTC Thunderbolt MicroSD Card Replacement, Battery: 3 단계, 이미지 1/2 HTC Thunderbolt MicroSD Card Replacement, Battery: 3 단계, 이미지 2/2
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. HTC Thunderbolt MicroSD Card Replacement, MicroSD Card: 4 단계, 이미지 1/2 HTC Thunderbolt MicroSD Card Replacement, MicroSD Card: 4 단계, 이미지 2/2
    • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
  5. HTC Thunderbolt MicroSD Card Replacement: 5 단계, 이미지 1/1
    • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
결론
Vanessa
회원 가입일: 01/18/13
60 평판
안내서 4개 작성하였습니다
Cal Poly, Team 19-45, Regan Winter 2013 Cal Poly, Team 19-45, Regan Winter 2013 회원
CPSU-REGAN-W13S19G45
4 회원들
안내서 24개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 6
전체 시간: 1,417
