소개
Warning: Always be sure you are grounded whenever handling any of the circuit or logic boards.
부품
부품은 필요하지 않습니다.
  1. Remove the back panel by sliding it up.
    • Remove the back panel by sliding it up.
  2. Remove the battery.
    • Remove the battery.
  3. Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
    • Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
  4. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  5. Use the plastic opening tool to remove the front panel from the phone. Unplug the front button cable from the inside of the phone.
    • Use the plastic opening tool to remove the front panel from the phone.
    • Unplug the front button cable from the inside of the phone.
  6. Unscrew the 2 torx-head screws at the base of the LCD screen using the T5 Torx Screwdriver.
    • Unscrew the 2 torx-head screws at the base of the LCD screen using the T5 Torx Screwdriver.
  7. Separate the motherboard from the black plastic casing. Unplug the black and red wire from the motherboard.
    • Separate the motherboard from the black plastic casing.
    • Unplug the black and red wire from the motherboard.
    • Unplug the black and red wire from the black plastic casing.
  8. Lift the black lever next to the orange ribbon cable to remove the LCD screen.
    • Lift the black lever next to the orange ribbon cable to remove the LCD screen.
  9. Remove the camera lens from the motherboard.
    • Remove the camera lens from the motherboard.
결론
callum rowland
회원 가입일: 2011년 04월 18일
247 평판
안내서 2개 작성하였습니다
Cal Poly, Team 15-12, Regan Spring 2011 Cal Poly, Team 15-12, Regan Spring 2011 회원
CPSU-REGAN-S11S15G12
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 7,604
