주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Touch Pro 2 Keyboard Replacement
필요한 것
  1. HTC Touch Pro 2 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 HTC Touch Pro 2 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 HTC Touch Pro 2 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Apply pressure and slide upward to remove back cover.
    • Lift the back cover up away from the phone.
  2. HTC Touch Pro 2 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 HTC Touch Pro 2 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Lift battery upward on the upper right-hand side to remove it.
    • Check the battery to make sure there's no bent corners.
  3. HTC Touch Pro 2 Keyboard Replacement, Housing: 3 단계, 이미지 2개 중 1개 HTC Touch Pro 2 Keyboard Replacement, Housing: 3 단계, 이미지 2개 중 2개
    • Using a T5 screwdriver, remove the four screws in corners as shown.
    • Lift the top portion of the rear case.
    • Potential for device damage: There is a ribbon attached on the back of this part that requires caution to remove.
  4. HTC Touch Pro 2 Keyboard Replacement: 4 단계, 이미지 3개 중 1개 HTC Touch Pro 2 Keyboard Replacement: 4 단계, 이미지 3개 중 2개 HTC Touch Pro 2 Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Using an IfixIt Plastic Tool, detach the plastic casing from the keyboard. This may require some force.
    • Using a spudger or other thin tool, carefully pry up ZIF connectors as shown. This will allow the black ribbons to detach from the keyboard.
    • Slide the two parts away from each other so that the black ribbons slide through the slots and you will now have housing into two parts.
  5. HTC Touch Pro 2 Keyboard Replacement, Keyboard: 5 단계, 이미지 3개 중 1개 HTC Touch Pro 2 Keyboard Replacement, Keyboard: 5 단계, 이미지 3개 중 2개 HTC Touch Pro 2 Keyboard Replacement, Keyboard: 5 단계, 이미지 3개 중 3개
    • Peel off the yellow ribbon shown slowly.
    • Unscrew the fours screws shown in red squares (two in each square) using a 00 screwdriver.
    • After the screws are out, you will be able to easily take off the small metal pieces circled in red.
  6. HTC Touch Pro 2 Keyboard Replacement: 6 단계, 이미지 3개 중 1개 HTC Touch Pro 2 Keyboard Replacement: 6 단계, 이미지 3개 중 2개 HTC Touch Pro 2 Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Slowly pull dual black strip off using force.
    • Behind the dual black strip is very sticky piece of grey tape. Use tweezers (preferably ones with ridges) to peel off the tape. Be careful not to rip it.
  7. HTC Touch Pro 2 Keyboard Replacement: 7 단계, 이미지 2개 중 1개 HTC Touch Pro 2 Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • Lift ZIF connectors up.
    • Carefully lift keyboard frame away from display screen.
    • You now have the keyboard detached.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Melinda Phan
회원 가입일: 04/17/11
438 평판
안내서 9개를 작성함
Cal Poly, Team 9-64, Walters Spring 2011 Cal Poly, Team 9-64, Walters Spring 2011 회원
CPSU-WALTERS-S11S9G64
5 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 78
전체 시간: 4,773
