소개
This easy to follow guide will show you in the ins and outs on how to repair your HTC Touch Pro.
  1. First, gently press on the back plate and push down toward the camera. First, gently press on the back plate and push down toward the camera.
    • First, gently press on the back plate and push down toward the camera.
  2. Use your finger to lift up the edge of the battery. Use your finger to lift up the edge of the battery.
    • Use your finger to lift up the edge of the battery.
  3. Remove the 4 screws using the T6 screw driver.
    • Remove the 4 screws using the T6 screw driver.
  4. Lift the plastic cover near the memory card slot. Lift the plastic cover near the memory card slot.
    • Lift the plastic cover near the memory card slot.
  5. Remove the two Phillips #00 screws from the backside of the screen.
    • Remove the two Phillips #00 screws from the backside of the screen.
  6. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  7. Insert a spudger or a plastic opening tool into the seam on the side of the phone. Gently pry apart the two halves of the phone.
    • Insert a spudger or a plastic opening tool into the seam on the side of the phone.
    • Gently pry apart the two halves of the phone.
  8. Gently unplug the connectors. Remove the screws with a 00 Phillips-head screwdriver.
    • Gently unplug the connectors.
    • Remove the screws with a 00 Phillips-head screwdriver.
  9. Gently lift the motherboard up using  a nylon spudger. BE AWARE OF THE ANTENNA.
    • Gently lift the motherboard up using a nylon spudger.
    • BE AWARE OF THE ANTENNA.
  10. Remove the 4 screws circled in red using a 00 Phillips-head screwdriver. Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
    • Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
  11. Start by lifting the back plate of the screen  by using yours finger or a plastic opener tool. Start by lifting the back plate of the screen  by using yours finger or a plastic opener tool.
    • Start by lifting the back plate of the screen by using yours finger or a plastic opener tool.
  12. Remove the 4 screws by using a 00 Phillips-head screwdriver.
    • Remove the 4 screws by using a 00 Phillips-head screwdriver.
    • Gently lift the connectors.
  13. Lift the front keyboard by removing the screws with a 00 Phillips-head screwdriver.
    • Lift the front keyboard by removing the screws with a 00 Phillips-head screwdriver.
  14. With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it . With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it . With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it .
    • With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it .
결론
다른 2명이 해당 안내서를 완성하였습니다.
Zhaowei Zhang
회원 가입일: 2011년 04월 28일
112 평판
안내서 4개 작성하였습니다
CSU Los Angeles, Team 1-6, Nelson Spring 2011 CSU Los Angeles, Team 1-6, Nelson Spring 2011 회원
CSULA-NELSON-S11S1G6
3 회원들
안내서 4개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 3,411
