주요 콘텐츠로 건너뛰기
HTC Touch Pro CDMA USB Motherboard Replacement
필요한 것
  1. HTC Touch Pro CDMA USB Motherboard Replacement, Battery: 1 단계, 이미지 1/2 HTC Touch Pro CDMA USB Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • First, gently press on the back plate and push down toward the camera.
  2. HTC Touch Pro CDMA USB Motherboard Replacement: 2 단계, 이미지 1/2 HTC Touch Pro CDMA USB Motherboard Replacement: 2 단계, 이미지 2/2
    • Use your finger to lift up the edge of the battery.
  3. HTC Touch Pro CDMA USB Motherboard Replacement, USB Logic Board: 3 단계, 이미지 1/1
    • Remove the 4 screws using the T6 screw driver.
  4. HTC Touch Pro CDMA USB Motherboard Replacement: 4 단계, 이미지 1/2 HTC Touch Pro CDMA USB Motherboard Replacement: 4 단계, 이미지 2/2
    • Lift the plastic cover near the memory card slot.
  5. HTC Touch Pro CDMA USB Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the two Phillips #00 screws from the backside of the screen.
  6. HTC Touch Pro CDMA USB Motherboard Replacement: 6 단계, 이미지 1/2 HTC Touch Pro CDMA USB Motherboard Replacement: 6 단계, 이미지 2/2
    • Insert a spudger or a plastic opening tool into the seam on the side of the phone.
    • Gently pry apart the two halves of the phone.
  7. HTC Touch Pro CDMA USB Motherboard Replacement: 7 단계, 이미지 1/2 HTC Touch Pro CDMA USB Motherboard Replacement: 7 단계, 이미지 2/2
    • Gently unplug the connectors.
    • Remove the screws with a 00 Phillips-head screwdriver.
  8. HTC Touch Pro CDMA USB Motherboard Replacement: 8 단계, 이미지 1/2 HTC Touch Pro CDMA USB Motherboard Replacement: 8 단계, 이미지 2/2
    • Gently lift the motherboard up using a nylon spudger.
    • BE AWARE OF THE ANTENNA.
결론
Zhaowei Zhang
회원 가입일: 04/28/11
133 평판
안내서 4개 작성하였습니다
CSU Los Angeles, Team 1-6, Nelson Spring 2011 CSU Los Angeles, Team 1-6, Nelson Spring 2011 회원
CSULA-NELSON-S11S1G6
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 3,042
