주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Replacement of the HTC Touch Pro's motherboard.
  1. First, gently press on the back plate and push down toward the camera. First, gently press on the back plate and push down toward the camera.
    • First, gently press on the back plate and push down toward the camera.
  2. Use your finger to lift up the edge of the battery. Use your finger to lift up the edge of the battery.
    • Use your finger to lift up the edge of the battery.
  3. Remove the 4 screws using the T6 screw driver.
    • Remove the 4 screws using the T6 screw driver.
  4. Lift the plastic cover near the memory card slot. Lift the plastic cover near the memory card slot.
    • Lift the plastic cover near the memory card slot.
  5. Remove the two Phillips #00 screws from the backside of the screen.
    • Remove the two Phillips #00 screws from the backside of the screen.
  6. Insert a spudger or a plastic opening tool into the seam on the side of the phone. Gently pry apart the two halves of the phone.
    • Insert a spudger or a plastic opening tool into the seam on the side of the phone.
    • Gently pry apart the two halves of the phone.
  7. Gently unplug the connectors. Remove the screws with a 00 Phillips-head screwdriver.
    • Gently unplug the connectors.
    • Remove the screws with a 00 Phillips-head screwdriver.
  8. Gently lift the motherboard up using  a nylon spudger. BE AWARE OF THE ANTENNA.
    • Gently lift the motherboard up using a nylon spudger.
    • BE AWARE OF THE ANTENNA.
결론
Zhaowei Zhang
회원 가입일: 2011년 04월 28일
112 평판
안내서 4개 작성하였습니다
CSU Los Angeles, Team 1-6, Nelson Spring 2011 CSU Los Angeles, Team 1-6, Nelson Spring 2011 회원
CSULA-NELSON-S11S1G6
3 회원들
안내서 4개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 2,953
