주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Touch Pro CDMA Verizon Camera Replacement
필요한 것
  1. HTC Touch Pro CDMA Verizon Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the back cover (not pictured) to your phone.
  2. HTC Touch Pro CDMA Verizon Camera Replacement: 2 단계, 이미지 2개 중 1개 HTC Touch Pro CDMA Verizon Camera Replacement: 2 단계, 이미지 2개 중 2개
    • To remove the battery, place your thumb beneath the tab and begin to lift.
    • Pinching the battery, lift up at an angle from the bottom of the phone.
  3. HTC Touch Pro CDMA Verizon Camera Replacement, Basic Parts: 3 단계, 이미지 1개 중 1개
    • Place the battery in a container off to the side. If you do this for every step beyond this point, you will keep better track of your parts and make reassembling the device far easier when you get around to it.
    • It might not be necessary, but we recommend using an anti-static bracelet or anti-static mat from this point on. Any charge on your finger tips may cause harm to the device.
  4. HTC Touch Pro CDMA Verizon Camera Replacement: 4 단계, 이미지 3개 중 1개 HTC Touch Pro CDMA Verizon Camera Replacement: 4 단계, 이미지 3개 중 2개 HTC Touch Pro CDMA Verizon Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Use a T6 screwdriver to remove the four screws on the rear plate of the HTC Touch Pro.
    • Place your screws in a bag labeled with where they came from, what screwdriver you used, and the order in which you removed them. For example, this bag would say "Rear casing. T6. #1."
  5. HTC Touch Pro CDMA Verizon Camera Replacement: 5 단계, 이미지 3개 중 1개 HTC Touch Pro CDMA Verizon Camera Replacement: 5 단계, 이미지 3개 중 2개 HTC Touch Pro CDMA Verizon Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Next, remove the casing that covers the camera and motherboard.
    • To do this, place your thumbnail in any of the grooves along either side and pry it open.
  6. HTC Touch Pro CDMA Verizon Camera Replacement: 6 단계, 이미지 2개 중 1개 HTC Touch Pro CDMA Verizon Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Insert your spudger along the slit between the keyboard and the external casing. Pry open as shown.
    • Careful! The ribbon connecting the keyboard to the motherboard will still connect the two halves of the phone when you separate them. Be sure to take your time and move slowly to avoid damage to the cable.
  7. HTC Touch Pro CDMA Verizon Camera Replacement: 7 단계, 이미지 3개 중 1개 HTC Touch Pro CDMA Verizon Camera Replacement: 7 단계, 이미지 3개 중 2개 HTC Touch Pro CDMA Verizon Camera Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the keyboard ribbon from the motherboard. To do this, simply grasp the ribbon at its base and pry it up at an angle. The ribbon has a metal end that is easily removed from the motherboard.
  8. HTC Touch Pro CDMA Verizon Camera Replacement: 8 단계, 이미지 3개 중 1개 HTC Touch Pro CDMA Verizon Camera Replacement: 8 단계, 이미지 3개 중 2개 HTC Touch Pro CDMA Verizon Camera Replacement: 8 단계, 이미지 3개 중 3개
    • Using a Phillips Head size 0 screwdriver, remove the 3 screws holding in the battery compartment.
    • Remove the ribbon covering the battery compartment by pinching it at the base and lifting.
  9. HTC Touch Pro CDMA Verizon Camera Replacement, Camera: 9 단계, 이미지 2개 중 1개 HTC Touch Pro CDMA Verizon Camera Replacement, Camera: 9 단계, 이미지 2개 중 2개
    • The camera is only held in by one connection to the motherboard and some tape.
    • Remove its connection to motherboard in the same way that you've removed such connections in the past.
  10. HTC Touch Pro CDMA Verizon Camera Replacement: 10 단계, 이미지 2개 중 1개 HTC Touch Pro CDMA Verizon Camera Replacement: 10 단계, 이미지 2개 중 2개
    • Peel the tape holding it in place.
    • After that it will be free to remove and replace as necessary.
결론
작성자
4다른 기여자 명과 함께
Jack Bowen
회원 가입일: 04/09/11
79 평판
안내서 5개를 작성함
Cal Poly, Team 20-67, Walters Spring 2011 Cal Poly, Team 20-67, Walters Spring 2011 회원
CPSU-WALTERS-S11S20G67
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 65
전체 시간: 1,686
