주요 콘텐츠로 건너뛰기
HTC TouchPro MP6950 Battery Replacement
필요한 것
  1. HTC TouchPro MP6950 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • This is the back of the phone.
    • Using your other eight fingers to cradle the phone, place each thumb on either side of the "Alltell" symbol.
    • Apply pressure towards your fingers, and then towards the top of the phone in a single movement.
  2. HTC TouchPro MP6950 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • After the cover stops moving forward, remove it by lifting the cover away from the phone.
    • In this photo, you will see the cover being removed from front to back. The cover can also be removed by lifting it straight back.
  3. HTC TouchPro MP6950 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Simple photo of the back of the phone with the rear cover off.
  4. HTC TouchPro MP6950 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • The small notch area is where the pressure to remove the battery will be applied.
  5. HTC TouchPro MP6950 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • To remove the battery, firmly hold the phone in one hand.
    • Using a finger, or in this case a plastic pry bar, apply pressure to this location, and pull battery back towards you.
  6. HTC TouchPro MP6950 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Be careful when removing the battery. If it comes in contact with any liquid, the battery can be ruined.
    • Simply lift the battery out of the battery tray.
  7. HTC TouchPro MP6950 Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Clockwise from the top: The removed battery, the rear cover, and the phone.
  8. HTC TouchPro MP6950 Battery Replacement: 8 단계, 이미지 1개 중 1개
    • If the battery is not working properly, water damage might be the culprit.
    • The small box on the right contains a white background with red hashes on top.
    • If the lines are sharp, there has been no forms of water damage.
    • If lines are blurry, or the background is pinkish, the has been water damage.
결론
작성자
5다른 기여자 명과 함께
Tyler
회원 가입일: 08/27/11
26 평판
안내서 1개를 작성함
Cuesta, Team 1-4, Zipperian Fall 2011 Cuesta, Team 1-4, Zipperian Fall 2011 회원
CUESTA-ZIPPERIAN-F11S1G4
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 391
