주요 콘텐츠로 건너뛰기
HTC Vive Compartment Cover Assembly Replacement
필요한 것
  1. HTC Vive Compartment Cover Assembly Replacement, Release the upper head strap: 1 단계, 이미지 1/2 HTC Vive Compartment Cover Assembly Replacement, Release the upper head strap: 1 단계, 이미지 2/2
    • Be sure to power down and disconnect your Vive before beginning.
    • Pull the hook-and-loop (Velcro) closure at the top of the head strap apart to release the top of the head strap.
  2. HTC Vive Compartment Cover Assembly Replacement, Remove the upper head strap: 2 단계, 이미지 1/2 HTC Vive Compartment Cover Assembly Replacement, Remove the upper head strap: 2 단계, 이미지 2/2
    • Slide the top part of the head strap through its metal loop on the headset to remove it.
  3. HTC Vive Compartment Cover Assembly Replacement, Open the cable compartment: 3 단계, 이미지 1/3 HTC Vive Compartment Cover Assembly Replacement, Open the cable compartment: 3 단계, 이미지 2/3 HTC Vive Compartment Cover Assembly Replacement, Open the cable compartment: 3 단계, 이미지 3/3
    • Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset.
    • Lift the cover away from the headset and slide it up the cables until it's out of the way.
  4. HTC Vive Compartment Cover Assembly Replacement, Unplug the HDMI cable: 4 단계, 이미지 1/2 HTC Vive Compartment Cover Assembly Replacement, Unplug the HDMI cable: 4 단계, 이미지 2/2
    • Lift the HDMI cable straight up to unplug it from the headset.
  5. HTC Vive Compartment Cover Assembly Replacement, Unplug the remaining cables: 5 단계, 이미지 1/3 HTC Vive Compartment Cover Assembly Replacement, Unplug the remaining cables: 5 단계, 이미지 2/3 HTC Vive Compartment Cover Assembly Replacement, Unplug the remaining cables: 5 단계, 이미지 3/3
    • Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
  6. HTC Vive Compartment Cover Assembly Replacement, Remove the compartment cover assembly: 6 단계, 이미지 1/2 HTC Vive Compartment Cover Assembly Replacement, Remove the compartment cover assembly: 6 단계, 이미지 2/2
    • Carefully slide the compartment cover assembly over the plugs and remove it.
결론
Adam O'Camb
회원 가입일: 04/11/15
196,590 평판
안내서 416개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 24
전체 시간: 1,778
