주요 콘텐츠로 건너뛰기
HTC Vive Cosmos Disassembly
필요한 것
  1. HTC Vive Cosmos Disassembly, Remove Faceplate: 1 단계, 이미지 1개 중 1개
    • pull from the nose and top middle to remove the face plate
  2. HTC Vive Cosmos Disassembly, Remove Frontplate: 2 단계, 이미지 1개 중 1개
    • Hold the button on the inside of the headset.
    • Pull back the frontplate away from the Vive.
  3. HTC Vive Cosmos Disassembly, Remove Warranty Stickers: 3 단계, 이미지 1개 중 1개
    • Peel the two warranty stickers using a driver.
    • Covers may be peeled back using other tools like a spudger.
  4. HTC Vive Cosmos Disassembly, Remove Camera Plate Screws: 4 단계, 이미지 1개 중 1개
    • Unscrew nineteen screws using the T5 Torx driver.
  5. HTC Vive Cosmos Disassembly, Remove Covers: 5 단계, 이미지 2개 중 1개 HTC Vive Cosmos Disassembly, Remove Covers: 5 단계, 이미지 2개 중 2개
    • Remove the covers beneath the warranty stickers.
  6. HTC Vive Cosmos Disassembly, Remove Plate: 6 단계, 이미지 1개 중 1개
    • Insert card between plate and camera plate to separate and remove.
    • May use card or other soft flat surfaces like a spudger.
  7. HTC Vive Cosmos Disassembly, Detach Headband: 7 단계, 이미지 1개 중 1개
    • Unscrew the three torx screws using the T5 X 50 mm screwdriver.
    • Unscrew the one Philips screw using the 10 mm screwdriver.
    • Detach headband from headset.
  8. HTC Vive Cosmos Disassembly, Remove Camera Plate: 8 단계, 이미지 1개 중 1개
    • Insert card between camera plate and the headset to separate.
  9. HTC Vive Cosmos Disassembly, Remove Focus Knob: 9 단계, 이미지 1개 중 1개
    • Slide the focus knob out of the plastic holding and off the focus rod.
  10. HTC Vive Cosmos Disassembly, Unplug Jumper Cables: 10 단계, 이미지 2개 중 1개 HTC Vive Cosmos Disassembly, Unplug Jumper Cables: 10 단계, 이미지 2개 중 2개
    • Static Warning for circuit board interaction. When dealing with jumper cables and circuit boards touch metal not located on Vive for 15 seconds before removing component. Keep in mind for remaining steps.
    • Unplug the jumper cables from the circuit boards to detach.
  11. HTC Vive Cosmos Disassembly, Detach Jumper Cables: 11 단계, 이미지 1개 중 1개
    • Unscrew the four silver Torx screws on the jumper cables using the T5 driver.
    • Keep note of the four silver Torx screws which are different than the other screws.
    • Pull the jumper cables away from the holding and remove.
  12. HTC Vive Cosmos Disassembly, Remove Cable Port Board Screws: 12 단계, 이미지 1개 중 1개
    • Unscrew the five black Torx screws using the T5 driver on the circuit board.[two more off the left of the image]
  13. HTC Vive Cosmos Disassembly, Remove Strip Plugs: 13 단계, 이미지 1개 중 1개
    • Remove the jumper cables to fully release the cable port board.
  14. HTC Vive Cosmos Disassembly, Unscrewing Camera Board: 14 단계, 이미지 1개 중 1개
    • Unscrew the six Torx Screws on the camera board with the T5 driver.
  15. HTC Vive Cosmos Disassembly, Remove Fan Screws: 15 단계, 이미지 1개 중 1개
    • Unscrew the one Torx Screw using the T5 driver.
  16. HTC Vive Cosmos Disassembly, Remove Heat Duct: 16 단계, 이미지 1개 중 1개
    • Pull and maneuver the heat duct out of the holding.
    • Exercise caution to carefully remove component.
    • The thermal paste may scratch off in the process but that is okay.
  17. HTC Vive Cosmos Disassembly, Unplug Fan: 17 단계, 이미지 2개 중 1개 HTC Vive Cosmos Disassembly, Unplug Fan: 17 단계, 이미지 2개 중 2개
    • Unplug the fan from the camera board.
  18. HTC Vive Cosmos Disassembly, Remove Additional Strip Plugs: 18 단계, 이미지 1개 중 1개
    • Insert screwdriver beneath strip plug to remove.
    • May use another tool that is able to fit beneath strip plug and gently remove.
  19. HTC Vive Cosmos Disassembly, Remove Camera Board: 19 단계, 이미지 1개 중 1개
    • Lift camera board and remove.
결론
작성자
2다른 기여자 명과 함께
Jalyssa Smith
회원 가입일: 04/11/23
289 평판
안내서 1개를 작성함
1가이드 댓글
Thanks for not mentioning the microphone and the fact that you also tore yours doing the disassembly! Will you replace the mic that was working before i took it apart to repair other issues? No? Exactly. Don't do any more guides and people: find a better one. Moron.
Lee Ball - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 52
전체 시간: 1,275
