주요 콘텐츠로 건너뛰기
HTC Vive Cosmos Headstrap Hinge Replacement
필요한 것
  1. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the facerest: 1 단계, 이미지 3개 중 1개 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the facerest: 1 단계, 이미지 3개 중 2개 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the facerest: 1 단계, 이미지 3개 중 3개
    • Pull the bottom of the facerest straight away from the Vive Cosmos to unclip it from the Vive.
    • With the bottom unclipped, pull the top of the facerest away from the Vive to remove it.
  2. HTC Vive Cosmos Headstrap Hinge Replacement, Unplug the audio connector: 2 단계, 이미지 3개 중 1개 HTC Vive Cosmos Headstrap Hinge Replacement, Unplug the audio connector: 2 단계, 이미지 3개 중 2개 HTC Vive Cosmos Headstrap Hinge Replacement, Unplug the audio connector: 2 단계, 이미지 3개 중 3개
    • Twist the 3.5 mm audio connector counter-clockwise slightly and slide its cable out from under the plastic retaining clip.
    • Lift the audio connector straight up to unplug it.
  3. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the front headstrap pad: 3 단계, 이미지 3개 중 1개 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the front headstrap pad: 3 단계, 이미지 3개 중 2개 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the front headstrap pad: 3 단계, 이미지 3개 중 3개
    • Grasp one end of the front headstrap pad and pull it away from the headstrap to remove it.
    • During reassembly, press the pads firmly against the headstrap, starting in the middle and moving toward the edges, until all the clips on the pads are completely seated in the headstrap. There should be no gaps between the pads and the headstrap.
  4. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the audio cables: 4 단계, 이미지 3개 중 1개 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the audio cables: 4 단계, 이미지 3개 중 2개 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the audio cables: 4 단계, 이미지 3개 중 3개
    • Carefully lift the audio connector cable out of its slot in the front of the headstrap.
  5. HTC Vive Cosmos Headstrap Hinge Replacement: 5 단계, 이미지 2개 중 1개 HTC Vive Cosmos Headstrap Hinge Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully lift the audio interconnect cable out of its slot in the front of the headstrap.
  6. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the headstrap: 6 단계, 이미지 1개 중 1개
    • Use a T5 Torx drive to remove the ten 4.1 mm long screws securing the headstrap.
  7. HTC Vive Cosmos Headstrap Hinge Replacement: 7 단계, 이미지 2개 중 1개 HTC Vive Cosmos Headstrap Hinge Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the headstrap.
  8. HTC Vive Cosmos Headstrap Hinge Replacement, Release the faceplate switch: 8 단계, 이미지 2개 중 1개 HTC Vive Cosmos Headstrap Hinge Replacement, Release the faceplate switch: 8 단계, 이미지 2개 중 2개
    • Use your finger to push the sliding faceplate release switch, sitting to the left of the lenses, toward the bottom of the Vive.
  9. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the faceplate: 9 단계, 이미지 2개 중 1개 HTC Vive Cosmos Headstrap Hinge Replacement, Remove the faceplate: 9 단계, 이미지 2개 중 2개
    • While holding the switch in the bottom position, pull the faceplate straight up and away from the front of the Vive.
    • Remove the faceplate.
  10. HTC Vive Cosmos Headstrap Hinge Replacement, Remove the headstrap hinge: 10 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the three 4.1 mm long screws securing the headstrap hinge.
  11. HTC Vive Cosmos Headstrap Hinge Replacement: 11 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to unscrew the captive screw securing the headstrap hinge.
    • There is a sticker covering this screw. Poke through it with your driver to access the screw.
  12. HTC Vive Cosmos Headstrap Hinge Replacement: 12 단계, 이미지 2개 중 1개 HTC Vive Cosmos Headstrap Hinge Replacement: 12 단계, 이미지 2개 중 2개
    • Slide the headstrap hinge out of its slot in the Vive and remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Adam O'Camb
회원 가입일: 04/11/15
217,168 평판
안내서 416개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 17
전체 시간: 1,119
