주요 콘텐츠로 건너뛰기
HTC Vive Cosmos headstrap Pads Replacement
필요한 것
  1. HTC Vive Cosmos headstrap Pads Replacement, Remove the rear headstrap pads: 1 단계, 이미지 1/3 HTC Vive Cosmos headstrap Pads Replacement, Remove the rear headstrap pads: 1 단계, 이미지 2/3 HTC Vive Cosmos headstrap Pads Replacement, Remove the rear headstrap pads: 1 단계, 이미지 3/3
    • Grasp the rear headstrap pad on one end and pull it away from the headstrap to remove it.
  2. HTC Vive Cosmos headstrap Pads Replacement, Remove the front headstrap pad: 2 단계, 이미지 1/3 HTC Vive Cosmos headstrap Pads Replacement, Remove the front headstrap pad: 2 단계, 이미지 2/3 HTC Vive Cosmos headstrap Pads Replacement, Remove the front headstrap pad: 2 단계, 이미지 3/3
    • Grasp the front headstrap pad on one end and pull it away from the headstrap to remove it.
    • During reassembly, press the pads firmly against the headstrap, starting in the middle and moving toward the edges, until all the clips on the pads are completely seated in the headstrap. There should be no gaps between the pads and the headstrap.
결론
Adam O'Camb
회원 가입일: 04/11/15
197,115 평판
안내서 416개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 14
전체 시간: 338
