주요 콘텐츠로 건너뛰기
HTC Vive Eyepiece Midframe Replacement
필요한 것
  1. HTC Vive Eyepiece Midframe Replacement, Open the cable compartment: 1 단계, 이미지 1/3 HTC Vive Eyepiece Midframe Replacement, Open the cable compartment: 1 단계, 이미지 2/3 HTC Vive Eyepiece Midframe Replacement, Open the cable compartment: 1 단계, 이미지 3/3
    • Be sure to power down and disconnect your Vive before beginning.
    • Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset.
    • Lift the cover away from the headset and slide it up the cables until it's out of the way.
  2. HTC Vive Eyepiece Midframe Replacement, Unplug the HDMI cable: 2 단계, 이미지 1/2 HTC Vive Eyepiece Midframe Replacement, Unplug the HDMI cable: 2 단계, 이미지 2/2
    • Lift the HDMI cable straight up to unplug it from the headset.
  3. HTC Vive Eyepiece Midframe Replacement, Unplug the remaining cables: 3 단계, 이미지 1/3 HTC Vive Eyepiece Midframe Replacement, Unplug the remaining cables: 3 단계, 이미지 2/3 HTC Vive Eyepiece Midframe Replacement, Unplug the remaining cables: 3 단계, 이미지 3/3
    • Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
  4. HTC Vive Eyepiece Midframe Replacement, Unscrew the outer shell: 4 단계, 이미지 1/3 HTC Vive Eyepiece Midframe Replacement, Unscrew the outer shell: 4 단계, 이미지 2/3 HTC Vive Eyepiece Midframe Replacement, Unscrew the outer shell: 4 단계, 이미지 3/3
    • Use tweezers to remove the small stickers over the four screws securing the outer shell.
    • Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
  5. HTC Vive Eyepiece Midframe Replacement, Remove the outer shell: 5 단계, 이미지 1/3 HTC Vive Eyepiece Midframe Replacement, Remove the outer shell: 5 단계, 이미지 2/3 HTC Vive Eyepiece Midframe Replacement, Remove the outer shell: 5 단계, 이미지 3/3
    • Grasp the top edge of the right half of the outer shell, behind the component cover and near the seam in the center. Pull it to the right and upward, away from the headset to release the clip securing that part of the shell.
  6. HTC Vive Eyepiece Midframe Replacement: 6 단계, 이미지 1/2 HTC Vive Eyepiece Midframe Replacement: 6 단계, 이미지 2/2
    • Grasp the right half the outer shell and pull it to the right and toward the front of the headset in a twisting motion until you feel the clips on the front of the cover release.
  7. HTC Vive Eyepiece Midframe Replacement: 7 단계, 이미지 1/2 HTC Vive Eyepiece Midframe Replacement: 7 단계, 이미지 2/2
    • Slide the right side of the outer shell to the right and off of the headset.
  8. HTC Vive Eyepiece Midframe Replacement: 8 단계, 이미지 1/2 HTC Vive Eyepiece Midframe Replacement: 8 단계, 이미지 2/2
    • Repeat the last three steps for the left side of the outer shell and remove it.
  9. HTC Vive Eyepiece Midframe Replacement, Remove the eyepiece midframe: 9 단계, 이미지 1/3 HTC Vive Eyepiece Midframe Replacement, Remove the eyepiece midframe: 9 단계, 이미지 2/3 HTC Vive Eyepiece Midframe Replacement, Remove the eyepiece midframe: 9 단계, 이미지 3/3
    • Hinge the OLED and lens frames down and away from the focus knob end of the eyepiece midframe.
    • Once you've rotated the OLED and lens frame about 90 degrees, push them straight down, parallel to the face of the eyepiece midframe, to separate them from the midframe.
결론
Adam O'Camb
회원 가입일: 04/11/15
196,656 평판
안내서 416개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 17
전체 시간: 868
