주요 콘텐츠로 건너뛰기
HTC Vive Focus CPU Fan Replacement
필요한 것
  1. HTC Vive Focus CPU Fan Replacement, Remove the facerest cushion: 1 단계, 이미지 3개 중 1개 HTC Vive Focus CPU Fan Replacement, Remove the facerest cushion: 1 단계, 이미지 3개 중 2개 HTC Vive Focus CPU Fan Replacement, Remove the facerest cushion: 1 단계, 이미지 3개 중 3개
    • Place your device upside-down on your work surface.
    • The facerest cushion is lightly held into place by seven plastic clips.
    • Use your fingers to gently pull the facerest cushion straight off of the facerest to remove it.
  2. HTC Vive Focus CPU Fan Replacement, Remove the facerest: 2 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the eight 4.5 mm screws securing the facerest.
    • One of the screws will be covered by a tamper-evident sticker. Press the driver through the sticker to remove the screw.
  3. HTC Vive Focus CPU Fan Replacement: 3 단계, 이미지 3개 중 1개 HTC Vive Focus CPU Fan Replacement: 3 단계, 이미지 3개 중 2개 HTC Vive Focus CPU Fan Replacement: 3 단계, 이미지 3개 중 3개
    • Insert an opening pick into the upper-left corner of the facerest.
    • Twist the opening pick to release the plastic clip securing the facerest.
    • Repeat for the upper-right corner.
    • Don't remove the facerest yet. It's still attached by the facerest sensor ribbon cable.
  4. HTC Vive Focus CPU Fan Replacement, Remove the facerest sensor: 4 단계, 이미지 3개 중 1개 HTC Vive Focus CPU Fan Replacement, Remove the facerest sensor: 4 단계, 이미지 3개 중 2개 HTC Vive Focus CPU Fan Replacement, Remove the facerest sensor: 4 단계, 이미지 3개 중 3개
    • Carefully flip your device over.
    • Pull the facerest out just enough to access the screws securing the facerest sensor.
    • Don't put any strain on the facerest sensor ribbon cable.
    • During reassembly, make sure the facerest sensor ribbon cable is positioned between the lenses before reinstalling the facerest.
  5. HTC Vive Focus CPU Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the two 2.4 mm screws securing the facerest sensor to the facerest.
  6. HTC Vive Focus CPU Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the facerest.
  7. HTC Vive Focus CPU Fan Replacement, Unscrew the front cover: 7 단계, 이미지 2개 중 1개 HTC Vive Focus CPU Fan Replacement, Unscrew the front cover: 7 단계, 이미지 2개 중 2개
    • Use your fingers to slide the lenses towards each other so that they are positioned towards the center of the device.
  8. HTC Vive Focus CPU Fan Replacement: 8 단계, 이미지 2개 중 1개 HTC Vive Focus CPU Fan Replacement: 8 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to remove the four screws securing the front cover from inside the device:
    • Two 5.7 mm screws with fine threads
    • Two 5.5 mm screws with coarse threads
    • The coarse-thread screws can strip easily. During reassembly, tighten the coarse-thread screws until they're hand tight and then no more.
  9. HTC Vive Focus CPU Fan Replacement, Remove the front cover: 9 단계, 이미지 2개 중 1개 HTC Vive Focus CPU Fan Replacement, Remove the front cover: 9 단계, 이미지 2개 중 2개
    • Note the location of the plastic welds on both vertical edges of the front cover.
    • After reassembly, the gap between the front cover and the side panels may no longer be flush. This is a cosmetic defect only and will not affect operation. The front cover's clips and screws are sufficient to secure it to the rest of the device.
  10. HTC Vive Focus CPU Fan Replacement: 10 단계, 이미지 3개 중 1개 HTC Vive Focus CPU Fan Replacement: 10 단계, 이미지 3개 중 2개 HTC Vive Focus CPU Fan Replacement: 10 단계, 이미지 3개 중 3개
    • Insert an opening pick into the top of the front cover near the upper left corner.
    • Slide the opening pick around the upper left corner of the front cover.
  11. HTC Vive Focus CPU Fan Replacement: 11 단계, 이미지 2개 중 1개 HTC Vive Focus CPU Fan Replacement: 11 단계, 이미지 2개 중 2개
    • Use the opening pick to separate the weld securing the left side vertical edge of the front cover.
    • The weld may require significant force to separate.
  12. HTC Vive Focus CPU Fan Replacement: 12 단계, 이미지 3개 중 1개 HTC Vive Focus CPU Fan Replacement: 12 단계, 이미지 3개 중 2개 HTC Vive Focus CPU Fan Replacement: 12 단계, 이미지 3개 중 3개
    • Insert an opening pick into the top of the front cover near the upper right corner.
    • Slide the opening pick around the upper right corner of the front cover.
  13. HTC Vive Focus CPU Fan Replacement: 13 단계, 이미지 2개 중 1개 HTC Vive Focus CPU Fan Replacement: 13 단계, 이미지 2개 중 2개
    • Use the opening pick to separate the weld securing the right side vertical edge of the front cover.
  14. HTC Vive Focus CPU Fan Replacement: 14 단계, 이미지 3개 중 1개 HTC Vive Focus CPU Fan Replacement: 14 단계, 이미지 3개 중 2개 HTC Vive Focus CPU Fan Replacement: 14 단계, 이미지 3개 중 3개
    • Flip the device upside-down.
    • Use an opening pick to disconnect the plastic clips securing the bottom right edge of the front cover to the device.
  15. HTC Vive Focus CPU Fan Replacement: 15 단계, 이미지 2개 중 1개 HTC Vive Focus CPU Fan Replacement: 15 단계, 이미지 2개 중 2개
    • Slide the opening pick along the bottom edge of the front cover to separate it from the device.
  16. HTC Vive Focus CPU Fan Replacement: 16 단계, 이미지 2개 중 1개 HTC Vive Focus CPU Fan Replacement: 16 단계, 이미지 2개 중 2개
    • Use the opening pick to disconnect the plastic clips securing the bottom-left edge of the front cover to the device.
  17. HTC Vive Focus CPU Fan Replacement: 17 단계, 이미지 2개 중 1개 HTC Vive Focus CPU Fan Replacement: 17 단계, 이미지 2개 중 2개
    • Flip the device right-side up.
    • Use the opening pick to separate the last few plastic clips securing the top of the front cover.
  18. HTC Vive Focus CPU Fan Replacement: 18 단계, 이미지 2개 중 1개 HTC Vive Focus CPU Fan Replacement: 18 단계, 이미지 2개 중 2개
    • Remove the front cover.
  19. HTC Vive Focus CPU Fan Replacement, Remove the CPU fan: 19 단계, 이미지 3개 중 1개 HTC Vive Focus CPU Fan Replacement, Remove the CPU fan: 19 단계, 이미지 3개 중 2개 HTC Vive Focus CPU Fan Replacement, Remove the CPU fan: 19 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $3.99
    • Use a pair of angled tweezers to disconnect the CPU fan cable from the motherboard.
    • Lift the CPU fan connector straight up from the motherboard to disconnect it from its socket.
    • During reassembly, align the CPU fan connector with its socket and use your finger to press it straight down into the motherboard.
  20. HTC Vive Focus CPU Fan Replacement: 20 단계, 이미지 2개 중 1개 HTC Vive Focus CPU Fan Replacement: 20 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to remove the three 5.5 mm screws securing the CPU fan.
    • Use a Phillips screwdriver to remove the two 2.3 mm screws securing the CPU heatsink.
  21. HTC Vive Focus CPU Fan Replacement: 21 단계, 이미지 2개 중 1개 HTC Vive Focus CPU Fan Replacement: 21 단계, 이미지 2개 중 2개
    • Remove the CPU fan.
    • During reassembly, do not sandwich the red antenna cable between the heatsink and contact plates.
결론
작성자
2다른 기여자 명과 함께
Sam Omiotek
회원 가입일: 02/25/19
92,212 평판
안내서 290개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 22
전체 시간: 489
