주요 콘텐츠로 건너뛰기
HTC Vive Focus Knob Replacement
필요한 것
  1. HTC Vive Focus Knob Replacement, Unscrew the outer shell: 1 단계, 이미지 1/3 HTC Vive Focus Knob Replacement, Unscrew the outer shell: 1 단계, 이미지 2/3 HTC Vive Focus Knob Replacement, Unscrew the outer shell: 1 단계, 이미지 3/3
    • Use tweezers to remove the small stickers over the four screws securing the outer shell.
    • Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
  2. HTC Vive Focus Knob Replacement, Remove the outer shell: 2 단계, 이미지 1/2 HTC Vive Focus Knob Replacement, Remove the outer shell: 2 단계, 이미지 2/2
    • Use the flat end of a spudger to pry up the top edge of the right half of the outer shell, behind the component cover and near the seam in the center, until it is unclipped from the headset.
  3. HTC Vive Focus Knob Replacement: 3 단계, 이미지 1/2 HTC Vive Focus Knob Replacement: 3 단계, 이미지 2/2
    • Grasp the right half the outer shell and pull it to the right and toward the front of the headset until you feel the clips on the front of the cover release.
    • If the shell is difficult to remove, try prying along the seam with the flat end of a spudger to release the clips.
  4. HTC Vive Focus Knob Replacement: 4 단계, 이미지 1/2 HTC Vive Focus Knob Replacement: 4 단계, 이미지 2/2
    • Slide the right side of the outer shell to the right and off of the headset.
  5. HTC Vive Focus Knob Replacement: 5 단계, 이미지 1/2 HTC Vive Focus Knob Replacement: 5 단계, 이미지 2/2
    • Repeat the last three steps for the left side of the outer shell and remove it.
  6. HTC Vive Focus Knob Replacement, Unscrew the focus knob: 6 단계, 이미지 1/1
    • Use a PH000 driver to remove the screw securing the focus knob.
  7. HTC Vive Focus Knob Replacement, Remove the focus knob: 7 단계, 이미지 1/2 HTC Vive Focus Knob Replacement, Remove the focus knob: 7 단계, 이미지 2/2
    • Slide the focus knob off of the focus rod and remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Adam O'Camb
회원 가입일: 04/11/15
196,659 평판
안내서 416개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 9
전체 시간: 1,366
