주요 콘텐츠로 건너뛰기
HTC Vive Head Strap Mounts Replacement
필요한 것
  1. HTC Vive Head Strap Mounts Replacement, Unscrew the head strap mounts: 1 단계, 이미지 1/2 HTC Vive Head Strap Mounts Replacement, Unscrew the head strap mounts: 1 단계, 이미지 2/2
    • Be sure to power down and disconnect your Vive before beginning.
    • Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
    • The mounts may fall off when the screws are removed, so be careful not to lose any parts.
  2. HTC Vive Head Strap Mounts Replacement, Remove the head strap mounts: 2 단계, 이미지 1/2 HTC Vive Head Strap Mounts Replacement, Remove the head strap mounts: 2 단계, 이미지 2/2
    • Remove the left head strap mount from the Vive.
  3. HTC Vive Head Strap Mounts Replacement, Separate the head strap mount components: 3 단계, 이미지 1/2 HTC Vive Head Strap Mounts Replacement, Separate the head strap mount components: 3 단계, 이미지 2/2
    • Pull the rubberized grip off of the head strap mount.
  4. HTC Vive Head Strap Mounts Replacement: 4 단계, 이미지 1/3 HTC Vive Head Strap Mounts Replacement: 4 단계, 이미지 2/3 HTC Vive Head Strap Mounts Replacement: 4 단계, 이미지 3/3
    • Push the internal locking mechanism out of the grip.
  5. HTC Vive Head Strap Mounts Replacement: 5 단계, 이미지 1/3 HTC Vive Head Strap Mounts Replacement: 5 단계, 이미지 2/3 HTC Vive Head Strap Mounts Replacement: 5 단계, 이미지 3/3
    • Repeat the previous three steps with the right head strap mount to remove it and separate its components.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Adam O'Camb
회원 가입일: 04/11/15
196,767 평판
안내서 416개 작성하였습니다
댓글 5개
how do you pute the headset back to getther on the vive.
GreggTHhompson - 답글
how do you put the strape back on the right way im stuk i need some help with it.
Gregg Thompson - 답글
Anybody knows where i can get the part, that is removed in step 3? On the picture it stays with the head strap mount, but the headstrap is sold without it. Im espacily looking for the plastic part, where the screw goes through.
MrBesen - 답글
same, if u found it lemme know
auris -
same man, my headstrap mount and a tracker dongle broke and theres no way to replace it. fml
arte beatti - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 52
전체 시간: 2,673
