주요 콘텐츠로 건너뛰기
HTC Vive Head Strap Replacement
필요한 것
  1. HTC Vive Head Strap Replacement, Release the upper head strap: 1 단계, 이미지 2개 중 1개 HTC Vive Head Strap Replacement, Release the upper head strap: 1 단계, 이미지 2개 중 2개
    • Be sure to power down and disconnect your Vive before beginning.
    • Pull the hook-and-loop (Velcro) closure at the top of the head strap apart to release the top of the head strap.
  2. HTC Vive Head Strap Replacement, Remove the upper head strap: 2 단계, 이미지 2개 중 1개 HTC Vive Head Strap Replacement, Remove the upper head strap: 2 단계, 이미지 2개 중 2개
    • Slide the top part of the head strap through its metal loop on the headset to remove it.
  3. HTC Vive Head Strap Replacement, Remove the right side of the head strap: 3 단계, 이미지 3개 중 1개 HTC Vive Head Strap Replacement, Remove the right side of the head strap: 3 단계, 이미지 3개 중 2개 HTC Vive Head Strap Replacement, Remove the right side of the head strap: 3 단계, 이미지 3개 중 3개
    • Pull the hook-and-loop closure at the right side of the head strap apart to release the right side of the head strap.
    • Slide the right side of the head strap through its metal loop to remove it.
  4. HTC Vive Head Strap Replacement, Remove the left side of the head strap: 4 단계, 이미지 3개 중 1개 HTC Vive Head Strap Replacement, Remove the left side of the head strap: 4 단계, 이미지 3개 중 2개 HTC Vive Head Strap Replacement, Remove the left side of the head strap: 4 단계, 이미지 3개 중 3개
    • Pull the hook-and-loop closure at the left side of the head strap apart to release the left side of the head strap.
    • Slide the left side of the head strap through its metal loop to remove it.
  5. HTC Vive Head Strap Replacement, Remove the head strap: 5 단계, 이미지 3개 중 1개 HTC Vive Head Strap Replacement, Remove the head strap: 5 단계, 이미지 3개 중 2개 HTC Vive Head Strap Replacement, Remove the head strap: 5 단계, 이미지 3개 중 3개
    • Slide the head strap along the cable, away from the Vive.
    • When the head strap comes to the end of the cable, gently slide it over the plugs and remove it.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Adam O'Camb
회원 가입일: 04/11/15
217,117 평판
안내서 416개를 작성함
3가이드 댓글
What is the name of the Part that holds the strap and has VIVE written on it ? Can I order that part individually ?
Elias - 답글
You can find that part, as well as the center strap holder by searching on eBay for HTC Vive headset parts. I’ve attached a link here: https://www.ebay.com/itm/Genuine-HTC-VIV...
Ryan Stargell -
how to fix my headset strap on my vive i nead some help on it can you show me how.
GreggTHhompson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 61
전체 시간: 7,133
