주요 콘텐츠로 건너뛰기
HTC Vive Lens and OLED Frames Replacement
필요한 것
  1. HTC Vive Lens and OLED Frames Replacement, Open the cable compartment: 1 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement, Open the cable compartment: 1 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement, Open the cable compartment: 1 단계, 이미지 3/3
    • Be sure to power down and disconnect your Vive before beginning.
    • Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset.
    • Lift the cover away from the headset and slide it up the cables until it's out of the way.
  2. HTC Vive Lens and OLED Frames Replacement, Unplug the HDMI cable: 2 단계, 이미지 1/2 HTC Vive Lens and OLED Frames Replacement, Unplug the HDMI cable: 2 단계, 이미지 2/2
    • Lift the HDMI cable straight up to unplug it from the headset.
  3. HTC Vive Lens and OLED Frames Replacement, Unplug the remaining cables: 3 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement, Unplug the remaining cables: 3 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement, Unplug the remaining cables: 3 단계, 이미지 3/3
    • Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
  4. HTC Vive Lens and OLED Frames Replacement, Unscrew the head strap mounts: 4 단계, 이미지 1/2 HTC Vive Lens and OLED Frames Replacement, Unscrew the head strap mounts: 4 단계, 이미지 2/2
    • Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
    • For some devices, a T6 Torx driver may work better.
    • The mounts may fall off when the screws are removed, so be careful not to lose any parts.
  5. HTC Vive Lens and OLED Frames Replacement, Remove the head strap mounts: 5 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement, Remove the head strap mounts: 5 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement, Remove the head strap mounts: 5 단계, 이미지 3/3
    • Remove both head strap mounts.
  6. HTC Vive Lens and OLED Frames Replacement, Remove the facerest: 6 단계, 이미지 1/2 HTC Vive Lens and OLED Frames Replacement, Remove the facerest: 6 단계, 이미지 2/2
    • Slide the facerest straight away from the headset to remove it.
  7. HTC Vive Lens and OLED Frames Replacement, Unscrew the outer shell: 7 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement, Unscrew the outer shell: 7 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement, Unscrew the outer shell: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use tweezers to remove the small stickers over the four screws securing the outer shell.
    • Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
  8. HTC Vive Lens and OLED Frames Replacement, Remove the outer shell: 8 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement, Remove the outer shell: 8 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement, Remove the outer shell: 8 단계, 이미지 3/3
    • Grasp the top edge of the right half of the outer shell, behind the component cover and near the seam in the center. Pull it to the right and upward, away from the headset to release the clip securing that part of the shell.
  9. HTC Vive Lens and OLED Frames Replacement: 9 단계, 이미지 1/2 HTC Vive Lens and OLED Frames Replacement: 9 단계, 이미지 2/2
    • Grasp the right half the outer shell and pull it to the right and toward the front of the headset in a twisting motion until you feel the clips on the front of the cover release.
  10. HTC Vive Lens and OLED Frames Replacement: 10 단계, 이미지 1/2 HTC Vive Lens and OLED Frames Replacement: 10 단계, 이미지 2/2
    • Slide the right side of the outer shell to the right and off of the headset.
  11. HTC Vive Lens and OLED Frames Replacement: 11 단계, 이미지 1/2 HTC Vive Lens and OLED Frames Replacement: 11 단계, 이미지 2/2
    • Repeat the last three steps for the left side of the outer shell and remove it.
  12. HTC Vive Lens and OLED Frames Replacement, Disconnect the sensor array cables: 12 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement, Disconnect the sensor array cables: 12 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement, Disconnect the sensor array cables: 12 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use tweezers to remove the clear tape over all four of the sensor array cable connectors.
  13. HTC Vive Lens and OLED Frames Replacement: 13 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement: 13 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement: 13 단계, 이미지 3/3
    • Use the pointed end of a spudger to flip up the small locking flap on one of the sensor array ZIF connectors.
    • Slide the cable straight out of its socket on the motherboard.
  14. HTC Vive Lens and OLED Frames Replacement: 14 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement: 14 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement: 14 단계, 이미지 3/3
    • Repeat the previous step for the remaining three sensor array cables to disconnect the remaining cables.
  15. HTC Vive Lens and OLED Frames Replacement: 15 단계, 이미지 1/2 HTC Vive Lens and OLED Frames Replacement: 15 단계, 이미지 2/2
    • Use tweezers or a spudger to pry up the camera cable cover and remove it.
  16. HTC Vive Lens and OLED Frames Replacement: 16 단계, 이미지 1/2 HTC Vive Lens and OLED Frames Replacement: 16 단계, 이미지 2/2
    • Use the flat end of a spudger to pry the camera cable connector straight up from its socket on the motherboard.
  17. HTC Vive Lens and OLED Frames Replacement, Unscrew the sensor array: 17 단계, 이미지 1/1
    • Use a PH000 driver to remove the five 3.9 mm screws securing the sensor array.
  18. HTC Vive Lens and OLED Frames Replacement: 18 단계, 이미지 1/1
    • Use a PH000 driver to remove the four 3.9 mm screws securing the sensor array.
  19. HTC Vive Lens and OLED Frames Replacement: 19 단계, 이미지 1/2 HTC Vive Lens and OLED Frames Replacement: 19 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Phillips #000 Screwdriver
    $5.49
    구매
    • You'll need a narrow, long-shaft driver to reach these screws.
  20. HTC Vive Lens and OLED Frames Replacement, Remove the sensor array: 20 단계, 이미지 1/2 HTC Vive Lens and OLED Frames Replacement, Remove the sensor array: 20 단계, 이미지 2/2
    • Lift the sensor array away from the headset to remove it.
  21. HTC Vive Lens and OLED Frames Replacement, Disconnect the motherboard: 21 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement, Disconnect the motherboard: 21 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement, Disconnect the motherboard: 21 단계, 이미지 3/3
    • Remove the tape covering the interconnect cable socket.
    • Use the point of a spudger to flip up the small locking flap on the cable socket.
    • Slide the interconnect cable straight out of its socket on the motherboard.
  22. HTC Vive Lens and OLED Frames Replacement: 22 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement: 22 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement: 22 단계, 이미지 3/3
    • Remove the tape covering the left OLED cable socket.
    • Slide the left OLED cable straight out of its socket on the motherboard.
  23. HTC Vive Lens and OLED Frames Replacement: 23 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement: 23 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement: 23 단계, 이미지 3/3
    • Remove the tape covering the right OLED cable socket.
    • Slide the right OLED cable straight out of its socket on the motherboard.
  24. HTC Vive Lens and OLED Frames Replacement: 24 단계, 이미지 1/2 HTC Vive Lens and OLED Frames Replacement: 24 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair tweezers to slightly twist the interconnect cable and press it down until the tabs on either side of the cable clear the hole in the motherboard.
    • During reassembly, make sure to thread the interconnect cable through its slot in the motherboard.
  25. HTC Vive Lens and OLED Frames Replacement, Remove the motherboard: 25 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement, Remove the motherboard: 25 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement, Remove the motherboard: 25 단계, 이미지 3/3
    • Press the non-port-end of the motherboard toward the top of headset while hinging it away from the midframe to free it from the clips securing that end.
    • Slide the motherboard toward the bottom of the headset, over the clips, to remove it.
    • Take care not to snag any cables during removal.
  26. HTC Vive Lens and OLED Frames Replacement, Disconnect the facerest midframe: 26 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement, Disconnect the facerest midframe: 26 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement, Disconnect the facerest midframe: 26 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to peel back the plastic covering the eyepiece midframe cable socket.
    • Use the pointed end of a spudger to flip up the plastic locking flap on the socket.
    • Slide the cable straight out of its socket to remove it.
  27. HTC Vive Lens and OLED Frames Replacement: 27 단계, 이미지 1/2 HTC Vive Lens and OLED Frames Replacement: 27 단계, 이미지 2/2
    • Gently peel the eyepiece midframe cable off of the facerest midframe.
  28. HTC Vive Lens and OLED Frames Replacement, Unscrew the facerest midframe: 28 단계, 이미지 1/1
    • Use a PH000 driver to remove the four 3.9 mm screws securing the facerest midframe.
  29. HTC Vive Lens and OLED Frames Replacement, Remove the facerest midframe: 29 단계, 이미지 1/2 HTC Vive Lens and OLED Frames Replacement, Remove the facerest midframe: 29 단계, 이미지 2/2
    • Lift the facerest midframe off of the eyepiece midframe.
  30. HTC Vive Lens and OLED Frames Replacement, Remove the eyepiece midframe: 30 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement, Remove the eyepiece midframe: 30 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement, Remove the eyepiece midframe: 30 단계, 이미지 3/3
    • Hinge the OLED and lens frames down and away from the focus knob end of the eyepiece midframe.
    • Once you've rotated the OLED and lens frame about 90 degrees, push them straight down, parallel to the face of the eyepiece midframe, to separate them from the midframe.
  31. HTC Vive Lens and OLED Frames Replacement, Remove the eyepiece gasket: 31 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement, Remove the eyepiece gasket: 31 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement, Remove the eyepiece gasket: 31 단계, 이미지 3/3
    • Gently lift the eyepiece gasket off of the lens and OLED frames to remove it.
  32. HTC Vive Lens and OLED Frames Replacement, Remove the support rod: 32 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement, Remove the support rod: 32 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement, Remove the support rod: 32 단계, 이미지 3/3
    • Pull the rubber bumpers off of either end of the support rod.
  33. HTC Vive Lens and OLED Frames Replacement: 33 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement: 33 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement: 33 단계, 이미지 3/3
    • Slide the support rod out of its brackets on the lens and OLED frames.
  34. HTC Vive Lens and OLED Frames Replacement, Remove the focus rod: 34 단계, 이미지 1/1
    • Use a PH000 driver to remove the eight 3.1 mm screws securing the focus rod brackets.
  35. HTC Vive Lens and OLED Frames Replacement: 35 단계, 이미지 1/1
    • Remove the focus rod and its brackets.
  36. HTC Vive Lens and OLED Frames Replacement, Unscrew the OLED covers: 36 단계, 이미지 1/1
    • Use a PH000 driver to remove the eight 2.4 mm screws securing the OLED covers.
  37. HTC Vive Lens and OLED Frames Replacement, Remove the OLED covers: 37 단계, 이미지 1/2 HTC Vive Lens and OLED Frames Replacement, Remove the OLED covers: 37 단계, 이미지 2/2
    • Use the flat end of a spudger push up one edge of the OLED cover and start unclipping that edge.
  38. HTC Vive Lens and OLED Frames Replacement: 38 단계, 이미지 1/2 HTC Vive Lens and OLED Frames Replacement: 38 단계, 이미지 2/2
    • Slide the spudger under the clip along that edge to free the rest of the edge.
  39. HTC Vive Lens and OLED Frames Replacement: 39 단계, 이미지 1/3 HTC Vive Lens and OLED Frames Replacement: 39 단계, 이미지 2/3 HTC Vive Lens and OLED Frames Replacement: 39 단계, 이미지 3/3
    • Slide the spudger around the remaining edges of the OLED cover to unclip those edges.
  40. HTC Vive Lens and OLED Frames Replacement: 40 단계, 이미지 1/2 HTC Vive Lens and OLED Frames Replacement: 40 단계, 이미지 2/2
    • Remove the OLED cover.
    • Repeat the last three steps to remove the other OLED cover.
    • During reassembly, remember to thread the OLED cables through their slots in the OLED cover.
  41. HTC Vive Lens and OLED Frames Replacement, Remove the OLED displays: 41 단계, 이미지 1/1
    • Very carefully lift the OLED display by its edges out of its frame.
    • If you are reusing the OLED displays, be very careful to avoid touching the front of the displays or bending or cracking the displays.
    • Repeat this process for the other OLED display.
  42. HTC Vive Lens and OLED Frames Replacement, Remove the lenses: 42 단계, 이미지 1/1
    • Apply an iOpener to the lens to soften the adhesive securing it to the frame.
  43. HTC Vive Lens and OLED Frames Replacement: 43 단계, 이미지 1/2 HTC Vive Lens and OLED Frames Replacement: 43 단계, 이미지 2/2
    • Use an opening tool to pry up the flat edge of the lens.
    • If it's difficult to pry up, apply the iOpener for another 30 seconds to further soften the adhesive.
  44. HTC Vive Lens and OLED Frames Replacement, Remove the lens: 44 단계, 이미지 1/1
    • Remove the lens.
    • Repeat the last two steps to remove the other lens.
    • Only the lens and OLED frames remain.
    • During reassembly, make sure the convex side of the lens is facing away from the frame.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Adam O'Camb
회원 가입일: 04/11/15
199,443 평판
안내서 416개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 30
30일 전: 144
전체 시간: 7,540
