주요 콘텐츠로 건너뛰기
HTC Vive Pro Daughterboard Replacement
필요한 것
  1. HTC Vive Pro Daughterboard Replacement, Reposition the head strap: 1 단계, 이미지 2개 중 1개 HTC Vive Pro Daughterboard Replacement, Reposition the head strap: 1 단계, 이미지 2개 중 2개
    • Rotate the head strap forward as far as it will go.
  2. HTC Vive Pro Daughterboard Replacement, Unplug the All-In-One Cable: 2 단계, 이미지 2개 중 1개 HTC Vive Pro Daughterboard Replacement, Unplug the All-In-One Cable: 2 단계, 이미지 2개 중 2개
    • Unplug the All-In-One Cable from your headset.
  3. HTC Vive Pro Daughterboard Replacement, Remove the All-In-One Cable: 3 단계, 이미지 3개 중 1개 HTC Vive Pro Daughterboard Replacement, Remove the All-In-One Cable: 3 단계, 이미지 3개 중 2개 HTC Vive Pro Daughterboard Replacement, Remove the All-In-One Cable: 3 단계, 이미지 3개 중 3개
    • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
    • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
  4. HTC Vive Pro Daughterboard Replacement, Remove the top strap: 4 단계, 이미지 2개 중 1개 HTC Vive Pro Daughterboard Replacement, Remove the top strap: 4 단계, 이미지 2개 중 2개
    • Separate the top strap from itself where the Velcro secures it.
  5. HTC Vive Pro Daughterboard Replacement: 5 단계, 이미지 3개 중 1개 HTC Vive Pro Daughterboard Replacement: 5 단계, 이미지 3개 중 2개 HTC Vive Pro Daughterboard Replacement: 5 단계, 이미지 3개 중 3개
    • Peel back the Velcro securing the rear of the top strap.
    • Feed the top strap out through the head strap to partially remove it.
  6. HTC Vive Pro Daughterboard Replacement: 6 단계, 이미지 3개 중 1개 HTC Vive Pro Daughterboard Replacement: 6 단계, 이미지 3개 중 2개 HTC Vive Pro Daughterboard Replacement: 6 단계, 이미지 3개 중 3개
    • Feed the top strap through the clip near the front of headset to fully remove it.
  7. HTC Vive Pro Daughterboard Replacement, Remove the front side foam pads: 7 단계, 이미지 3개 중 1개 HTC Vive Pro Daughterboard Replacement, Remove the front side foam pads: 7 단계, 이미지 3개 중 2개 HTC Vive Pro Daughterboard Replacement, Remove the front side foam pads: 7 단계, 이미지 3개 중 3개
    • Peel off both front side foam pads to uncover the speaker wires.
  8. HTC Vive Pro Daughterboard Replacement, Remove the two rubber spacers: 8 단계, 이미지 3개 중 1개 HTC Vive Pro Daughterboard Replacement, Remove the two rubber spacers: 8 단계, 이미지 3개 중 2개 HTC Vive Pro Daughterboard Replacement, Remove the two rubber spacers: 8 단계, 이미지 3개 중 3개
    • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
    • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
  9. HTC Vive Pro Daughterboard Replacement, Disconnect the speaker wires: 9 단계, 이미지 3개 중 1개 HTC Vive Pro Daughterboard Replacement, Disconnect the speaker wires: 9 단계, 이미지 3개 중 2개 HTC Vive Pro Daughterboard Replacement, Disconnect the speaker wires: 9 단계, 이미지 3개 중 3개
    • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
  10. HTC Vive Pro Daughterboard Replacement, Remove the head strap: 10 단계, 이미지 2개 중 1개 HTC Vive Pro Daughterboard Replacement, Remove the head strap: 10 단계, 이미지 2개 중 2개
    • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
    • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
    • Four 3.9 mm screws (two on each side)
    • Two 4.1 mm screws (one on each side)
  11. HTC Vive Pro Daughterboard Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
  12. HTC Vive Pro Daughterboard Replacement: 12 단계, 이미지 3개 중 1개 HTC Vive Pro Daughterboard Replacement: 12 단계, 이미지 3개 중 2개 HTC Vive Pro Daughterboard Replacement: 12 단계, 이미지 3개 중 3개
    • Thread the headphone speaker wires out through both ends of the head strap.
  13. HTC Vive Pro Daughterboard Replacement, Remove the outer shell: 13 단계, 이미지 3개 중 1개 HTC Vive Pro Daughterboard Replacement, Remove the outer shell: 13 단계, 이미지 3개 중 2개 HTC Vive Pro Daughterboard Replacement, Remove the outer shell: 13 단계, 이미지 3개 중 3개
    • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
  14. HTC Vive Pro Daughterboard Replacement: 14 단계, 이미지 2개 중 1개 HTC Vive Pro Daughterboard Replacement: 14 단계, 이미지 2개 중 2개
    • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
  15. HTC Vive Pro Daughterboard Replacement: 15 단계, 이미지 3개 중 1개 HTC Vive Pro Daughterboard Replacement: 15 단계, 이미지 3개 중 2개 HTC Vive Pro Daughterboard Replacement: 15 단계, 이미지 3개 중 3개
    • Insert an opening pick into the seam between the two halves of the outer shell.
    • Slide the opening pick through the seam to dislodge the clips securing it to the headset.
    • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
  16. HTC Vive Pro Daughterboard Replacement: 16 단계, 이미지 3개 중 1개 HTC Vive Pro Daughterboard Replacement: 16 단계, 이미지 3개 중 2개 HTC Vive Pro Daughterboard Replacement: 16 단계, 이미지 3개 중 3개
    • Continue sliding the opening pick through each seam until all clips have been dislodged.
  17. HTC Vive Pro Daughterboard Replacement: 17 단계, 이미지 3개 중 1개 HTC Vive Pro Daughterboard Replacement: 17 단계, 이미지 3개 중 2개 HTC Vive Pro Daughterboard Replacement: 17 단계, 이미지 3개 중 3개
    • Carefully slide each half of the outer shell off of the sensor array.
    • Be careful not to snag any of the ribbon cables underneath.
  18. HTC Vive Pro Daughterboard Replacement, Remove the face rest cushion: 18 단계, 이미지 3개 중 1개 HTC Vive Pro Daughterboard Replacement, Remove the face rest cushion: 18 단계, 이미지 3개 중 2개 HTC Vive Pro Daughterboard Replacement, Remove the face rest cushion: 18 단계, 이미지 3개 중 3개
    • Use your fingers to gently peel the face rest cushion off of the headset.
  19. HTC Vive Pro Daughterboard Replacement, Remove the facerest: 19 단계, 이미지 2개 중 1개 HTC Vive Pro Daughterboard Replacement, Remove the facerest: 19 단계, 이미지 2개 중 2개
    • Partially separate the facerest and the sensor array to access the daughterboard.
  20. HTC Vive Pro Daughterboard Replacement: 20 단계, 이미지 2개 중 1개 HTC Vive Pro Daughterboard Replacement: 20 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the Kapton tape covering the white and purple wires on the daughterboard.
  21. HTC Vive Pro Daughterboard Replacement: 21 단계, 이미지 3개 중 1개 HTC Vive Pro Daughterboard Replacement: 21 단계, 이미지 3개 중 2개 HTC Vive Pro Daughterboard Replacement: 21 단계, 이미지 3개 중 3개
    • Use the pointed end of a spudger to pry up and disconnect the purple and white wires from the daughterboard.
    • Use caution when disconnecting these wires. If you pry up too hard, they may pull out of the connector.
  22. HTC Vive Pro Daughterboard Replacement: 22 단계, 이미지 2개 중 1개 HTC Vive Pro Daughterboard Replacement: 22 단계, 이미지 2개 중 2개
    • Slide the facerest out of the front assembly.
  23. HTC Vive Pro Daughterboard Replacement, Remove the sensor array: 23 단계, 이미지 2개 중 1개 HTC Vive Pro Daughterboard Replacement, Remove the sensor array: 23 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the Kapton tape covering the ZIF connector on the daughterboard.
  24. HTC Vive Pro Daughterboard Replacement: 24 단계, 이미지 3개 중 1개 HTC Vive Pro Daughterboard Replacement: 24 단계, 이미지 3개 중 2개 HTC Vive Pro Daughterboard Replacement: 24 단계, 이미지 3개 중 3개
    • Use the pointed end of a spudger to flip up the locking flap on the daughterboard ZIF connector.
    • Use a pair of tweezers to slide the ribbon cable out of its socket.
  25. HTC Vive Pro Daughterboard Replacement: 25 단계, 이미지 2개 중 1개 HTC Vive Pro Daughterboard Replacement: 25 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to peel back the grey tape covering the ZIF connector on the motherboard underneath the sensor array.
  26. HTC Vive Pro Daughterboard Replacement: 26 단계, 이미지 3개 중 1개 HTC Vive Pro Daughterboard Replacement: 26 단계, 이미지 3개 중 2개 HTC Vive Pro Daughterboard Replacement: 26 단계, 이미지 3개 중 3개
    • Use the flat end of your spudger to flip up the locking flap for the ZIF connector on the motherboard.
    • Use the pointed end of your spudger to disconnect the ribbon cable from the motherboard.
  27. HTC Vive Pro Daughterboard Replacement: 27 단계, 이미지 2개 중 1개 HTC Vive Pro Daughterboard Replacement: 27 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to remove the four 3.0 mm silver screws securing the sensor array to the lens and OLED assembly.
    • Use a T6 Torx screwdriver to remove the four black 3.8 mm screws securing the sensor array.
  28. HTC Vive Pro Daughterboard Replacement: 28 단계, 이미지 2개 중 1개 HTC Vive Pro Daughterboard Replacement: 28 단계, 이미지 2개 중 2개
    • Lift the sensor array straight up off of the lens and OLED assembly.
  29. HTC Vive Pro Daughterboard Replacement, Remove the daughterboard: 29 단계, 이미지 3개 중 1개 HTC Vive Pro Daughterboard Replacement, Remove the daughterboard: 29 단계, 이미지 3개 중 2개 HTC Vive Pro Daughterboard Replacement, Remove the daughterboard: 29 단계, 이미지 3개 중 3개
    • Use the flat end of your spudger to disconnect the two press connectors from the daughterboard.
  30. HTC Vive Pro Daughterboard Replacement: 30 단계, 이미지 2개 중 1개 HTC Vive Pro Daughterboard Replacement: 30 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the Kapton tape covering the last remaining ZIF connector.
  31. HTC Vive Pro Daughterboard Replacement: 31 단계, 이미지 3개 중 1개 HTC Vive Pro Daughterboard Replacement: 31 단계, 이미지 3개 중 2개 HTC Vive Pro Daughterboard Replacement: 31 단계, 이미지 3개 중 3개
    • Use the pointed end of your spudger to flip up the locking flap on the ZIF connector.
    • Use a pair of tweezers to disconnect the ribbon cable from the ZIF connector.
  32. HTC Vive Pro Daughterboard Replacement: 32 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the four 3.0 mm screws securing the daughterboard.
  33. HTC Vive Pro Daughterboard Replacement: 33 단계, 이미지 1개 중 1개
    • Remove the daughterboard.
    • During reassembly, don't forget to reinstall any Kapton tape that was removed during disassembly. This will prevent malfunction of the sensors.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sam Omiotek
회원 가입일: 02/25/19
92,782 평판
안내서 290개를 작성함
2가이드 댓글
Hi!
I've got a problem where the port itself seems to be the problem. the vive pro connects and disconnects contantly when you shake the cable a bit.
is there a simple fix?
1BalBal1 - 답글
Unfort, no. The female port on the daughterboard has became loose from the solder and the daughterboard needs to be either replaced or the video/audio port needs to be re-soldered. There just simply is no ...easy fix.
Crystal Stanford - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 29
전체 시간: 1,340
