주요 콘텐츠로 건너뛰기
HTC Vive Pro Outer Shell Replacement
필요한 것
  1. HTC Vive Pro Outer Shell Replacement, Reposition the head strap: 1 단계, 이미지 1/2 HTC Vive Pro Outer Shell Replacement, Reposition the head strap: 1 단계, 이미지 2/2
    • Rotate the head strap forward as far as it will go.
  2. HTC Vive Pro Outer Shell Replacement, Unplug the All-In-One Cable: 2 단계, 이미지 1/2 HTC Vive Pro Outer Shell Replacement, Unplug the All-In-One Cable: 2 단계, 이미지 2/2
    • Unplug the All-In-One Cable from your headset.
  3. HTC Vive Pro Outer Shell Replacement, Remove the All-In-One Cable: 3 단계, 이미지 1/3 HTC Vive Pro Outer Shell Replacement, Remove the All-In-One Cable: 3 단계, 이미지 2/3 HTC Vive Pro Outer Shell Replacement, Remove the All-In-One Cable: 3 단계, 이미지 3/3
    • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
    • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
  4. HTC Vive Pro Outer Shell Replacement, Remove the top strap: 4 단계, 이미지 1/2 HTC Vive Pro Outer Shell Replacement, Remove the top strap: 4 단계, 이미지 2/2
    • Separate the top strap from itself where the velcro secures it.
  5. HTC Vive Pro Outer Shell Replacement: 5 단계, 이미지 1/3 HTC Vive Pro Outer Shell Replacement: 5 단계, 이미지 2/3 HTC Vive Pro Outer Shell Replacement: 5 단계, 이미지 3/3
    • Peel back the Velcro securing the rear of the top strap.
    • Feed the top strap out through the head strap to remove it.
  6. HTC Vive Pro Outer Shell Replacement: 6 단계, 이미지 1/3 HTC Vive Pro Outer Shell Replacement: 6 단계, 이미지 2/3 HTC Vive Pro Outer Shell Replacement: 6 단계, 이미지 3/3
    • Feed the top strap through the clip on the headset to fully remove it.
  7. HTC Vive Pro Outer Shell Replacement, Remove the front side foam pads: 7 단계, 이미지 1/3 HTC Vive Pro Outer Shell Replacement, Remove the front side foam pads: 7 단계, 이미지 2/3 HTC Vive Pro Outer Shell Replacement, Remove the front side foam pads: 7 단계, 이미지 3/3
    • Peel off both front side foam pads to uncover the speaker wires.
  8. HTC Vive Pro Outer Shell Replacement, Remove two rubber spacers: 8 단계, 이미지 1/3 HTC Vive Pro Outer Shell Replacement, Remove two rubber spacers: 8 단계, 이미지 2/3 HTC Vive Pro Outer Shell Replacement, Remove two rubber spacers: 8 단계, 이미지 3/3
    • Insert the pointed end of your spudger behind the square rubber spacer next to each headphone screw.
    • Gently pry the rubber spacers out of the head strap.
    • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
  9. HTC Vive Pro Outer Shell Replacement, Disconnect the speaker wires: 9 단계, 이미지 1/2 HTC Vive Pro Outer Shell Replacement, Disconnect the speaker wires: 9 단계, 이미지 2/2
    • Use the pointed end of your spudger to pry up and disconnect both the left and right headphone speaker wires.
  10. HTC Vive Pro Outer Shell Replacement, Remove the head strap: 10 단계, 이미지 1/2 HTC Vive Pro Outer Shell Replacement, Remove the head strap: 10 단계, 이미지 2/2
    • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
    • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
    • Four 3.9 mm screws (two on each side)
    • Two 4.1 mm screws (one on each side)
  11. HTC Vive Pro Outer Shell Replacement: 11 단계, 이미지 1/1
    • Remove the two plastic spacers underneath the previously removed screws from the headset.
  12. HTC Vive Pro Outer Shell Replacement: 12 단계, 이미지 1/3 HTC Vive Pro Outer Shell Replacement: 12 단계, 이미지 2/3 HTC Vive Pro Outer Shell Replacement: 12 단계, 이미지 3/3
    • Thread the headphone speaker wires out through the ends of the head strap.
  13. HTC Vive Pro Outer Shell Replacement, Remove the outer shell: 13 단계, 이미지 1/3 HTC Vive Pro Outer Shell Replacement, Remove the outer shell: 13 단계, 이미지 2/3 HTC Vive Pro Outer Shell Replacement, Remove the outer shell: 13 단계, 이미지 3/3
    • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
  14. HTC Vive Pro Outer Shell Replacement: 14 단계, 이미지 1/2 HTC Vive Pro Outer Shell Replacement: 14 단계, 이미지 2/2
    • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
  15. HTC Vive Pro Outer Shell Replacement: 15 단계, 이미지 1/3 HTC Vive Pro Outer Shell Replacement: 15 단계, 이미지 2/3 HTC Vive Pro Outer Shell Replacement: 15 단계, 이미지 3/3
    • Insert an opening pick into the crease between the two halves of the outer shell.
    • Slide the opening pick through the crease to dislodge the clips securing it to the headset.
    • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
    • Continue sliding the opening pick through each crease until all clips have been dislodged.
  16. HTC Vive Pro Outer Shell Replacement: 16 단계, 이미지 1/3 HTC Vive Pro Outer Shell Replacement: 16 단계, 이미지 2/3 HTC Vive Pro Outer Shell Replacement: 16 단계, 이미지 3/3
    • Carefully slide each half of the outer shell off of the sensor array.
    • Use caution not to snag any of the ribbon cables underneath.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Sam Omiotek
회원 가입일: 02/25/19
75,062 평판
안내서 288개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 307
