주요 콘텐츠로 건너뛰기
HTC Vive Sensor Array Replacement
필요한 것
  1. HTC Vive Sensor Array Replacement, Open the cable compartment: 1 단계, 이미지 1/3 HTC Vive Sensor Array Replacement, Open the cable compartment: 1 단계, 이미지 2/3 HTC Vive Sensor Array Replacement, Open the cable compartment: 1 단계, 이미지 3/3
    • Be sure to power down and disconnect your Vive before beginning.
    • Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset.
    • Lift the cover away from the headset and slide it up the cables until it's out of the way.
  2. HTC Vive Sensor Array Replacement, Unplug the HDMI cable: 2 단계, 이미지 1/2 HTC Vive Sensor Array Replacement, Unplug the HDMI cable: 2 단계, 이미지 2/2
    • Lift the HDMI cable straight up to unplug it from the headset.
  3. HTC Vive Sensor Array Replacement, Unplug the remaining cables: 3 단계, 이미지 1/3 HTC Vive Sensor Array Replacement, Unplug the remaining cables: 3 단계, 이미지 2/3 HTC Vive Sensor Array Replacement, Unplug the remaining cables: 3 단계, 이미지 3/3
    • Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
  4. HTC Vive Sensor Array Replacement, Unscrew the head strap mounts: 4 단계, 이미지 1/2 HTC Vive Sensor Array Replacement, Unscrew the head strap mounts: 4 단계, 이미지 2/2
    • Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
    • For some devices, a T6 Torx driver may work better.
    • The mounts may fall off when the screws are removed, so be careful not to lose any parts.
  5. HTC Vive Sensor Array Replacement, Remove the head strap mounts: 5 단계, 이미지 1/3 HTC Vive Sensor Array Replacement, Remove the head strap mounts: 5 단계, 이미지 2/3 HTC Vive Sensor Array Replacement, Remove the head strap mounts: 5 단계, 이미지 3/3
    • Remove both head strap mounts.
  6. HTC Vive Sensor Array Replacement, Remove the facerest: 6 단계, 이미지 1/2 HTC Vive Sensor Array Replacement, Remove the facerest: 6 단계, 이미지 2/2
    • Slide the facerest straight away from the headset to remove it.
  7. HTC Vive Sensor Array Replacement, Unscrew the outer shell: 7 단계, 이미지 1/3 HTC Vive Sensor Array Replacement, Unscrew the outer shell: 7 단계, 이미지 2/3 HTC Vive Sensor Array Replacement, Unscrew the outer shell: 7 단계, 이미지 3/3
    • Use tweezers to remove the small stickers over the four screws securing the outer shell.
    • Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
  8. HTC Vive Sensor Array Replacement, Remove the outer shell: 8 단계, 이미지 1/3 HTC Vive Sensor Array Replacement, Remove the outer shell: 8 단계, 이미지 2/3 HTC Vive Sensor Array Replacement, Remove the outer shell: 8 단계, 이미지 3/3
    • Grasp the top edge of the right half of the outer shell, behind the component cover and near the seam in the center. Pull it to the right and upward, away from the headset to release the clip securing that part of the shell.
  9. HTC Vive Sensor Array Replacement: 9 단계, 이미지 1/2 HTC Vive Sensor Array Replacement: 9 단계, 이미지 2/2
    • Grasp the right half the outer shell and pull it to the right and toward the front of the headset in a twisting motion until you feel the clips on the front of the cover release.
  10. HTC Vive Sensor Array Replacement: 10 단계, 이미지 1/2 HTC Vive Sensor Array Replacement: 10 단계, 이미지 2/2
    • Slide the right side of the outer shell to the right and off of the headset.
  11. HTC Vive Sensor Array Replacement: 11 단계, 이미지 1/2 HTC Vive Sensor Array Replacement: 11 단계, 이미지 2/2
    • Repeat the last three steps for the left side of the outer shell and remove it.
  12. HTC Vive Sensor Array Replacement, Disconnect the sensor array cables: 12 단계, 이미지 1/3 HTC Vive Sensor Array Replacement, Disconnect the sensor array cables: 12 단계, 이미지 2/3 HTC Vive Sensor Array Replacement, Disconnect the sensor array cables: 12 단계, 이미지 3/3
    • Use tweezers to remove the clear tape over all four of the sensor array cable connectors.
  13. HTC Vive Sensor Array Replacement: 13 단계, 이미지 1/3 HTC Vive Sensor Array Replacement: 13 단계, 이미지 2/3 HTC Vive Sensor Array Replacement: 13 단계, 이미지 3/3
    • Use the pointed end of a spudger to flip up the small locking flap on one of the sensor array ZIF connectors.
    • Slide the cable straight out of its socket on the motherboard.
  14. HTC Vive Sensor Array Replacement: 14 단계, 이미지 1/3 HTC Vive Sensor Array Replacement: 14 단계, 이미지 2/3 HTC Vive Sensor Array Replacement: 14 단계, 이미지 3/3
    • Repeat the previous step for the remaining three sensor array cables to disconnect the remaining cables.
  15. HTC Vive Sensor Array Replacement: 15 단계, 이미지 1/2 HTC Vive Sensor Array Replacement: 15 단계, 이미지 2/2
    • Use tweezers or a spudger to pry up the camera cable cover and remove it.
  16. HTC Vive Sensor Array Replacement: 16 단계, 이미지 1/2 HTC Vive Sensor Array Replacement: 16 단계, 이미지 2/2
    • Use the flat end of a spudger to pry the camera cable connector straight up from its socket on the motherboard.
  17. HTC Vive Sensor Array Replacement, Unscrew the sensor array: 17 단계, 이미지 1/1
    • Use a PH000 driver to remove the five 3.9 mm screws securing the sensor array.
  18. HTC Vive Sensor Array Replacement: 18 단계, 이미지 1/1
    • Use a PH000 driver to remove the four 3.9 mm screws securing the sensor array.
  19. HTC Vive Sensor Array Replacement: 19 단계, 이미지 1/2 HTC Vive Sensor Array Replacement: 19 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Phillips #000 Screwdriver
    $5.49
    구매
    • You'll need a narrow, long-shaft driver to reach these screws.
  20. HTC Vive Sensor Array Replacement, Remove the sensor array: 20 단계, 이미지 1/2 HTC Vive Sensor Array Replacement, Remove the sensor array: 20 단계, 이미지 2/2
    • Lift the sensor array away from the headset to remove it.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Adam O'Camb
회원 가입일: 04/11/15
196,194 평판
안내서 416개 작성하였습니다
댓글 한 개
Herzlichen Dank für diese ausführliche Anleitung! Sie war sehr hilfreich und hat mir vermutlich eine Menge Zeit erspart!
Holger - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 24
전체 시간: 2,859
