주요 콘텐츠로 건너뛰기
HTC Vive XR Elite Fan Replacement
필요한 것
  1. HTC Vive XR Elite Fan Replacement, Prepare your Vive XR Elite for disassembly: 1 단계, 이미지 1개 중 1개
    • Before starting this repair, discharge the batteries in your headset below 25%. A charged battery may leak dangerous chemicals or catch fire if damaged.
    • Playing Half Life: Alyx will do the trick!
    • The Vive XR Elite has a proximity sensor that puts the headset in standby mode to save battery when it isn't in use. To drain the battery faster you'll need to use the headset.
  2. HTC Vive XR Elite Fan Replacement, Disconnect the USB-C power cable: 2 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the USB-C power cable: 2 단계, 이미지 2개 중 2개
    • Disconnect the USB-C power cable.
  3. HTC Vive XR Elite Fan Replacement, Disconnect the battery cradle: 3 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the battery cradle: 3 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Disconnect the battery cradle: 3 단계, 이미지 3개 중 3개
    • Press the release button on the right battery cradle temple slot.
    • Pull the battery cradle away from the right temple slot to disconnect it.
  4. HTC Vive XR Elite Fan Replacement: 4 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement: 4 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement: 4 단계, 이미지 3개 중 3개
    • Repeat the previous step for the left temple slot.
  5. HTC Vive XR Elite Fan Replacement, Separate the headset and battery cradle: 5 단계, 이미지 1개 중 1개
    • Separate the headset and battery cradle.
  6. HTC Vive XR Elite Fan Replacement, Remove the face cushion: 6 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Remove the face cushion: 6 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Remove the face cushion: 6 단계, 이미지 3개 중 3개
    • The face cushion is attached to the headset with two magnets. You'll feel the pull of the magnets as you remove it.
    • Grip the middle of the face cushion with your fingers and pull back to remove it.
  7. HTC Vive XR Elite Fan Replacement, Remove the screw covers: 7 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Remove the screw covers: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to remove the six screw covers from the right temple.
  8. HTC Vive XR Elite Fan Replacement, Unfasten the right temple: 8 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Unfasten the right temple: 8 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two right temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the right hinge cover.
  9. HTC Vive XR Elite Fan Replacement, Remove the outer hinge cover: 9 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Remove the outer hinge cover: 9 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Remove the outer hinge cover: 9 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger in the gap between the right outer and inner hinge covers.
    • Slide the spudger along the gap to separate the clips securing the outer hinge cover.
    • Remove the outer hinge cover.
  10. HTC Vive XR Elite Fan Replacement, Remove the outer temple: 10 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Remove the outer temple: 10 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Remove the outer temple: 10 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger in the gap between the outer and inner temple.
    • Slide the spudger along the gap to separate the clips securing the outer temple.
  11. HTC Vive XR Elite Fan Replacement: 11 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement: 11 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement: 11 단계, 이미지 3개 중 3개
    • Slide the top of the outer temple out of its slot in the hinge.
  12. HTC Vive XR Elite Fan Replacement: 12 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement: 12 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $6.99
    • The speaker is lightly adhered to the outer temple.
    • Rotate the outer temple towards you to access the speaker.
    • Slide the flat end of a spudger under the speaker to separate its adhesive.
    • During reassembly, if your speaker adhesive isn't sticky, use double-sided tape to re-adhere the speaker to the outer temple.
  13. HTC Vive XR Elite Fan Replacement: 13 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement: 13 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement: 13 단계, 이미지 3개 중 3개
    • Thread the outer temple off of the USB‑C cable and remove it.
  14. HTC Vive XR Elite Fan Replacement: 14 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement: 14 단계, 이미지 2개 중 2개
    • Pull the inner temple out of its slot in the hinge and remove it.
  15. HTC Vive XR Elite Fan Replacement, Peel the hinge tape: 15 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Peel the hinge tape: 15 단계, 이미지 2개 중 2개
    • Use tweezers to peel back the black tape covering one of the inner hinge cover screws.
  16. HTC Vive XR Elite Fan Replacement, Unfasten the inner hinge cover: 16 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the two screws securing the inner hinge cover:
    • One 3.1 mm‑long screw
    • One 4.9 mm‑long screw
  17. HTC Vive XR Elite Fan Replacement, Remove the inner hinge cover: 17 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Remove the inner hinge cover: 17 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Remove the inner hinge cover: 17 단계, 이미지 3개 중 3개
    • Rotate the inner hinge cover off its groove in the frame.
    • Thread the inner hinge cover off of the USB-C and speaker cables and remove it.
  18. HTC Vive XR Elite Fan Replacement, Remove the screw covers: 18 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Remove the screw covers: 18 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to remove the six screw covers from the left temple.
  19. HTC Vive XR Elite Fan Replacement, Unfasten the left temple: 19 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Unfasten the left temple: 19 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two left temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the left hinge cover.
  20. HTC Vive XR Elite Fan Replacement, Remove the outer hinge cover: 20 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Remove the outer hinge cover: 20 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Remove the outer hinge cover: 20 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger in the gap between the left outer and inner hinge covers.
  21. HTC Vive XR Elite Fan Replacement, Remove the left temple: 21 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Remove the left temple: 21 단계, 이미지 2개 중 2개
    • Pull the left temple out of its slot in the hinge.
    • Don't try to fully remove it yet, as it's still connected by a cable.
  22. HTC Vive XR Elite Fan Replacement: 22 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement: 22 단계, 이미지 2개 중 2개
    • Slide the spudger along the gap to separate the plastic clips securing the outer temple.
  23. HTC Vive XR Elite Fan Replacement: 23 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement: 23 단계, 이미지 2개 중 2개
    • Pull the outer temple off of its inner half to completely release its plastic clips.
  24. HTC Vive XR Elite Fan Replacement: 24 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement: 24 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $6.99
    • Let the speaker rest next to the headset before continuing.
    • During reassembly, if your speaker adhesive isn't sticky, use Tesa 61395 Tape to re-adhere the speaker to the outer temple.
  25. HTC Vive XR Elite Fan Replacement, Peel the hinge tape: 25 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Peel the hinge tape: 25 단계, 이미지 2개 중 2개
  26. HTC Vive XR Elite Fan Replacement, Unfasten the inner hinge cover: 26 단계, 이미지 1개 중 1개
    • One 3.5 mm‑long screw
  27. HTC Vive XR Elite Fan Replacement, Reposition the inner hinge cover: 27 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Reposition the inner hinge cover: 27 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Reposition the inner hinge cover: 27 단계, 이미지 3개 중 3개
    • Don't fully remove the inner hinge cover, as it's connected by the volume button cable.
    • Let the cover hang off its volume button cable for now.
  28. HTC Vive XR Elite Fan Replacement, Unfasten the face plate: 28 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Unfasten the face plate: 28 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to remove the 12 screws securing the face plate:
    • Six 3.5 mm‑long screws
    • Four 4.9 mm‑long screws
    • Two 6.5 mm‑long screws
    • There are two magnets at the top corners of the face plate. As you remove nearby screws, they might stick to them.
  29. HTC Vive XR Elite Fan Replacement, Unclip the face cover: 29 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Unclip the face cover: 29 단계, 이미지 2개 중 2개
    • Insert the flat end of the spudger in the gap between the frame and the bottom right corner of the face cover.
    • Pry up with the spudger to release the clips securing the face cover.
  30. HTC Vive XR Elite Fan Replacement: 30 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement: 30 단계, 이미지 2개 중 2개
    • Repeat the prying process for the middle and bottom left portions of the face cover.
  31. HTC Vive XR Elite Fan Replacement, Reposition the face cover: 31 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Reposition the face cover: 31 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Reposition the face cover: 31 단계, 이미지 3개 중 3개
    • Don't fully remove the face cover completely, as it's connected by the proximity sensor cable.
    • Lift the face cover and rotate it over the top of the frame.
    • Lay the face cover face up before continuing.
  32. HTC Vive XR Elite Fan Replacement, Unfasten the proximity sensor: 32 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the two 3.3 mm‑long screws securing the proximity sensor cable.
  33. HTC Vive XR Elite Fan Replacement, Remove the face cover: 33 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Remove the face cover: 33 단계, 이미지 2개 중 2개
    • Remove the face cover.
  34. HTC Vive XR Elite Fan Replacement, Reposition the lens assembly: 34 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Reposition the lens assembly: 34 단계, 이미지 2개 중 2개
    • Pull the two lenses outward so they're as far apart as possible.
  35. HTC Vive XR Elite Fan Replacement, Unfasten the lens assembly: 35 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the four screws securing the lens assembly:
    • Three 4.9 mm‑long screws
    • One 3.3 mm‑long screw
  36. HTC Vive XR Elite Fan Replacement, Remove the brackets: 36 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Remove the brackets: 36 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Remove the brackets: 36 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • The screw brackets are secured with clips and adhesive.
    • Use tweezers to pull the left screw bracket of its post in the frame.
    • This may require some force. Be careful not to scratch any surrounding components.
    • Repeat this process for the right bracket.
    • During reassembly, use tweezers to align the brackets on their posts. Press down with the flat end of a spudger to engage and re-adhere the clips.
  37. HTC Vive XR Elite Fan Replacement, Reposition the lens assembly: 37 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Reposition the lens assembly: 37 단계, 이미지 2개 중 2개
    • Lift the bottom of the lens assembly up to separate the bottom rails from their slots in the frame.
  38. HTC Vive XR Elite Fan Replacement: 38 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement: 38 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement: 38 단계, 이미지 3개 중 3개
    • Pull the lens assembly upwards to separate the top rails from their slots in the frame.
    • Rotate the lens assembly towards the top of the frame so it sits upright with its cable connectors exposed.
  39. HTC Vive XR Elite Fan Replacement, Unfasten the lens assembly cables: 39 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the four 3.4 mm‑long screws securing the lens assembly cables.
  40. HTC Vive XR Elite Fan Replacement, Disconnect the lens assembly cables: 40 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the lens assembly cables: 40 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Disconnect the lens assembly cables: 40 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry up and disconnect the lens assembly cable connector.
    • Repeat this procedure for the other connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  41. HTC Vive XR Elite Fan Replacement, Remove the lens assembly: 41 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Remove the lens assembly: 41 단계, 이미지 2개 중 2개
    • Lift up and remove the lens assembly.
  42. HTC Vive XR Elite Fan Replacement, Reassembly information: 42 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Reassembly information: 42 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Reassembly information: 42 단계, 이미지 3개 중 3개
    • The next four steps demonstrate how to secure the lens assembly to the frame during reassembly.
    • In order for the lens assembly to rest in the frame properly, it needs to align with a peg in the IPD (interpupillary distance) slider.
    • Before reinstalling the lens assembly, push the IPD slider to its right-most position.
  43. HTC Vive XR Elite Fan Replacement: 43 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement: 43 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement: 43 단계, 이미지 3개 중 3개
    • Pull the lens assembly outward until its plastic clips sit close to the end of the top rails.
    • You may need to push and pull the top rail so it sits evenly across the plastic clips.
  44. HTC Vive XR Elite Fan Replacement: 44 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement: 44 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement: 44 단계, 이미지 3개 중 3개
    • Push the bottom rails inwards as far as they will go.
  45. HTC Vive XR Elite Fan Replacement: 45 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement: 45 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement: 45 단계, 이미지 3개 중 3개
    • To secure the lens assembly into the frame:
    • Slide the top left rail into its slot.
    • Align the other rails.
    • Press the lens assembly into place, making sure to realign the center peg.
  46. HTC Vive XR Elite Fan Replacement, Peel the tape: 46 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Peel the tape: 46 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Peel the tape: 46 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
  47. HTC Vive XR Elite Fan Replacement: 47 단계, 이미지 1개 중 1개
    • Peel off the yellow tape covering the proximity sensor connector.
  48. HTC Vive XR Elite Fan Replacement, Disconnect the proximity sensor: 48 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the proximity sensor: 48 단계, 이미지 2개 중 2개
    • Use the point of a spudger to lift up the locking flap on the proximity sensor ZIF connector.
  49. HTC Vive XR Elite Fan Replacement: 49 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement: 49 단계, 이미지 2개 중 2개
    • Use tweezers to pull the proximity sensor cable out of its slot in the motherboard.
  50. HTC Vive XR Elite Fan Replacement, Remove the proximity sensor: 50 단계, 이미지 1개 중 1개
    • Remove the proximity sensor.
  51. HTC Vive XR Elite Fan Replacement, Peel the tape: 51 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Peel the tape: 51 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Peel the tape: 51 단계, 이미지 3개 중 3개
    • Peel off the yellow tape covering the motion sensor cable.
  52. HTC Vive XR Elite Fan Replacement, Unfasten the motion sensor: 52 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the two 3.4 mm‑long screws securing the motion sensor.
  53. HTC Vive XR Elite Fan Replacement, Reposition the motion sensor: 53 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Reposition the motion sensor: 53 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Reposition the motion sensor: 53 단계, 이미지 3개 중 3개
    • Don't try to fully remove the motion sensor yet, as it's still connected by a cable.
    • Lift the motion sensor off its pegs in the frame.
    • Flip over the motion sensor and lay it on the frame before continuing.
  54. HTC Vive XR Elite Fan Replacement, Peel the tape: 54 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Peel the tape: 54 단계, 이미지 2개 중 2개
    • Peel off the yellow tape covering the motion sensor cable connector.
  55. HTC Vive XR Elite Fan Replacement, Disconnect the motion sensor: 55 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the motion sensor: 55 단계, 이미지 2개 중 2개
    • Use the point of a spudger to lift up the locking flap on the motion sensor ZIF connector.
  56. HTC Vive XR Elite Fan Replacement, Remove the motion sensor: 56 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Remove the motion sensor: 56 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to pull the motion sensor cable connector out of its slot.
    • Remove the motion sensor.
  57. HTC Vive XR Elite Fan Replacement, Disconnect the right speaker: 57 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the right speaker: 57 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Disconnect the right speaker: 57 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to pull the right speaker connector out of its socket.
    • If you're having trouble, try rocking the connector side-to-side to help loosen it.
  58. HTC Vive XR Elite Fan Replacement, Remove the right speaker: 58 단계, 이미지 1개 중 1개
    • Remove the right speaker.
  59. HTC Vive XR Elite Fan Replacement, Disconnect the left speaker: 59 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the left speaker: 59 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Disconnect the left speaker: 59 단계, 이미지 3개 중 3개
    • Use tweezers to pull the left speaker connector out of its socket.
  60. HTC Vive XR Elite Fan Replacement, Remove the left speaker: 60 단계, 이미지 1개 중 1개
    • Remove the left speaker.
  61. HTC Vive XR Elite Fan Replacement, Separate the volume button cable: 61 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Separate the volume button cable: 61 단계, 이미지 2개 중 2개
    • The volume button cable is lightly adhered to the left inner hinge cover.
    • Insert one arm of your tweezers between the volume button cable and the hinge cover.
    • Pry away from the hinge cover to separate the adhesive.
  62. HTC Vive XR Elite Fan Replacement: 62 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement: 62 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement: 62 단계, 이미지 3개 중 3개
    • Use your tweezers to pull the volume button cable out of its slot in the hinge cover.
  63. HTC Vive XR Elite Fan Replacement, Disconnect the bottom left antenna: 63 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the bottom left antenna: 63 단계, 이미지 2개 중 2개
    • Use one arm of your tweezers to pry up and disconnect the bottom left antenna cable.
    • During reassembly, these can be tricky to reconnect. Hold the connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  64. HTC Vive XR Elite Fan Replacement, Reposition the bottom left antenna cable: 64 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Reposition the bottom left antenna cable: 64 단계, 이미지 2개 중 2개
  65. HTC Vive XR Elite Fan Replacement, Unfasten the motion sensor bracket: 65 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the two 4.9 mm‑long screws securing the motion sensor bracket.
  66. HTC Vive XR Elite Fan Replacement, Remove the motion sensor bracket: 66 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Remove the motion sensor bracket: 66 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Remove the motion sensor bracket: 66 단계, 이미지 3개 중 3개
    • Lift the motion sensor off its pegs on the motherboard.
    • Remove the motion sensor bracket.
  67. HTC Vive XR Elite Fan Replacement, Peel the tape: 67 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Peel the tape: 67 단계, 이미지 2개 중 2개
    • Use tweezers to peel back the gray conductive tape covering the left side‑camera ZIF connector.
  68. HTC Vive XR Elite Fan Replacement: 68 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement: 68 단계, 이미지 2개 중 2개
    • Use tweezers to peel off the black tape covering the left side‑camera ZIF connector.
  69. HTC Vive XR Elite Fan Replacement, Disconnect the left side camera: 69 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the left side camera: 69 단계, 이미지 2개 중 2개
    • Use flat end of a spudger to lift up the locking flap on the left side‑camera ZIF connector.
  70. HTC Vive XR Elite Fan Replacement: 70 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement: 70 단계, 이미지 2개 중 2개
    • Use tweezers to pull the left side‑camera cable connector out of its slot in the motherboard.
  71. HTC Vive XR Elite Fan Replacement, Peel the tape: 71 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Peel the tape: 71 단계, 이미지 2개 중 2개
    • Use tweezers to peel back the gray conductive tape covering the left tracking camera ZIF connector.
  72. HTC Vive XR Elite Fan Replacement: 72 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement: 72 단계, 이미지 2개 중 2개
    • Use tweezers to peel off the black tape covering the left tracking camera ZIF connector.
  73. HTC Vive XR Elite Fan Replacement, Disconnect the left tracking camera: 73 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the left tracking camera: 73 단계, 이미지 2개 중 2개
    • Use a spudger to lift up the locking flap on the left tracking camera ZIF connector.
  74. HTC Vive XR Elite Fan Replacement: 74 단계, 이미지 1개 중 1개
    • Use tweezers to pull the left tracking camera cable connector out of its slot in the motherboard.
  75. HTC Vive XR Elite Fan Replacement, Disconnect the antennas: 75 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the antennas: 75 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Disconnect the antennas: 75 단계, 이미지 3개 중 3개
  76. HTC Vive XR Elite Fan Replacement, Peel the tape: 76 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Peel the tape: 76 단계, 이미지 2개 중 2개
  77. HTC Vive XR Elite Fan Replacement: 77 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement: 77 단계, 이미지 2개 중 2개
    • Use tweezers to peel off the black tape covering the pass-through camera ZIF connector.
  78. HTC Vive XR Elite Fan Replacement, Disconnect the pass-through camera: 78 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the pass-through camera: 78 단계, 이미지 2개 중 2개
    • Use a spudger to lift up the locking flap on the pass-through camera ZIF connector.
  79. HTC Vive XR Elite Fan Replacement: 79 단계, 이미지 1개 중 1개
    • Use tweezers to pull the pass-through camera cable connector out of its slot in the motherboard.
  80. HTC Vive XR Elite Fan Replacement, Peel the tape: 80 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Peel the tape: 80 단계, 이미지 2개 중 2개
  81. HTC Vive XR Elite Fan Replacement, Disconnect the microphone: 81 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the microphone: 81 단계, 이미지 2개 중 2개
    • Use the point of a spudger to lift up the locking flap on the microphone ZIF connector.
  82. HTC Vive XR Elite Fan Replacement: 82 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement: 82 단계, 이미지 2개 중 2개
    • Use tweezers to pull the microphone cable connector out of its slot in the motherboard.
  83. HTC Vive XR Elite Fan Replacement, Disconnect the depth sensor: 83 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the depth sensor: 83 단계, 이미지 2개 중 2개
    • Use tweezers to pull the depth sensor cable connector out of its slot in the motherboard.
  84. HTC Vive XR Elite Fan Replacement, Peel the tape: 84 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Peel the tape: 84 단계, 이미지 2개 중 2개
    • Use tweezers to peel back the gray conductive tape covering the right tracking camera ZIF connector.
  85. HTC Vive XR Elite Fan Replacement: 85 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement: 85 단계, 이미지 2개 중 2개
    • Use tweezers to peel off the black tape covering the right tracking camera ZIF connector.
  86. HTC Vive XR Elite Fan Replacement, Disconnect the right tracking camera: 86 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the right tracking camera: 86 단계, 이미지 2개 중 2개
    • Use a spudger to lift up the locking flap on the right tracking camera ZIF connector.
  87. HTC Vive XR Elite Fan Replacement: 87 단계, 이미지 1개 중 1개
    • Use tweezers to pull the right tracking camera cable connector out of its slot.
  88. HTC Vive XR Elite Fan Replacement, Peel the tape: 88 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Peel the tape: 88 단계, 이미지 2개 중 2개
    • Use tweezers to peel back the gray conductive tape covering the right side‑camera ZIF connector.
  89. HTC Vive XR Elite Fan Replacement: 89 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement: 89 단계, 이미지 2개 중 2개
    • Use tweezers to peel off the black tape covering the right side‑camera ZIF connector.
  90. HTC Vive XR Elite Fan Replacement, Disconnect the right side camera: 90 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the right side camera: 90 단계, 이미지 2개 중 2개
    • Use a spudger to lift up the locking flap on the right side-camera ZIF connector.
  91. HTC Vive XR Elite Fan Replacement: 91 단계, 이미지 1개 중 1개
    • Use tweezers to pull the right side‑camera cable connector out of its slot.
  92. HTC Vive XR Elite Fan Replacement, Unfasten the motherboard frame: 92 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the two 4.9 mm‑long screws securing the motherboard frame.
  93. HTC Vive XR Elite Fan Replacement, Tape the cables: 93 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Tape the cables: 93 단계, 이미지 2개 중 2개
    • Use tape with light adhesive, such as painter's tape, to keep the left and right side cables away from the motherboard.
    • The cables near the top edge need slack for the motherboard to rest properly in the frame. Avoid taping them tightly—or avoid taping them altogether.
  94. HTC Vive XR Elite Fan Replacement, Disconnect the power button: 94 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the power button: 94 단계, 이미지 2개 중 2개
    • Lift the power button out of its slot in the frame.
    • Don't remove the button completely, as it's still attached by a cable.
  95. HTC Vive XR Elite Fan Replacement, Remove the IPD slider: 95 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Remove the IPD slider: 95 단계, 이미지 2개 중 2개
    • Press down the bottom right corner of the motherboard so its edge rests under the IPD slider.
  96. HTC Vive XR Elite Fan Replacement: 96 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement: 96 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement: 96 단계, 이미지 3개 중 3개
    • While pressing down on the motherboard, push the IPD slider out of its slot in the frame.
    • Remove the IPD slider.
  97. HTC Vive XR Elite Fan Replacement, Remove the motherboard assembly: 97 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Remove the motherboard assembly: 97 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Remove the motherboard assembly: 97 단계, 이미지 3개 중 3개
    • Grip the USB-C port with one hand and the right side of the frame with the other.
    • Pull the frame outward while lifting the motherboard assembly until it clears its slot next to the right side‑camera.
    • Use a spudger to pry up the motherboard assembly until its right side completely clears the frame.
  98. HTC Vive XR Elite Fan Replacement: 98 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement: 98 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement: 98 단계, 이미지 3개 중 3개
    • Pull the right side of the motherboard assembly toward the bottom edge of the device to separate it from the frame.
    • Remove the motherboard assembly.
    • During reassembly, make sure the cables stay above the motherboard assembly as you reinstall it.
  99. HTC Vive XR Elite Fan Replacement, Disconnect the battery: 99 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the battery: 99 단계, 이미지 2개 중 2개
    • Flip the motherboard assembly over so the fan is facing upward.
    • Use the point of a spudger to pry up and disconnect the headset battery press connector.
  100. HTC Vive XR Elite Fan Replacement, Disconnect the fan: 100 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Disconnect the fan: 100 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to pull the fan cable connector out of its slot in the motherboard.
  101. HTC Vive XR Elite Fan Replacement, Peel the tape: 101 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Peel the tape: 101 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Peel the tape: 101 단계, 이미지 3개 중 3개
    • Peel off the black tape covering the top of the fan.
  102. HTC Vive XR Elite Fan Replacement, Remove the heat sink cover: 102 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Remove the heat sink cover: 102 단계, 이미지 2개 중 2개
    • Pull the heatsink cover off the motherboard frame and remove it.
  103. HTC Vive XR Elite Fan Replacement, Disassembly information: 103 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Disassembly information: 103 단계, 이미지 2개 중 2개
    • The fan is secured with adhesive around its perimeter.
    • The middle portion of the fan housing exposes the motherboard. Keep tools away from the middle of the fan to avoid damaging the motherboard.
  104. HTC Vive XR Elite Fan Replacement, Separate the fan adhesive: 104 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement, Separate the fan adhesive: 104 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement, Separate the fan adhesive: 104 단계, 이미지 3개 중 3개
    • Support the motherboard with one hand before during this step.
    • Insert the flat end of the spudger under the top right corner of the fan.
    • Slide the spudger under the top of the fan to separate the top adhesive.
  105. HTC Vive XR Elite Fan Replacement: 105 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement: 105 단계, 이미지 2개 중 2개
    • Insert the flat end of the spudger under the bottom right corner of the fan.
    • Only insert the spudger up to 5 mm to avoid touching the motherboard.
    • Twist the spudger to separate the bottom adhesive.
  106. HTC Vive XR Elite Fan Replacement: 106 단계, 이미지 3개 중 1개 HTC Vive XR Elite Fan Replacement: 106 단계, 이미지 3개 중 2개 HTC Vive XR Elite Fan Replacement: 106 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger under the lip in the fan's peg hole.
    • Lift up with the spudger to separate the remaining fan adhesive.
  107. HTC Vive XR Elite Fan Replacement, Remove the fan: 107 단계, 이미지 2개 중 1개 HTC Vive XR Elite Fan Replacement, Remove the fan: 107 단계, 이미지 2개 중 2개
    • Lift the fan out of its housing and remove it.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
작성자
1다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
212,590 평판
안내서 1,039개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,608개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 6
전체 시간: 199
