주요 콘텐츠로 건너뛰기
HTC Warhawk Buttons Replacement
필요한 것
  1. HTC Warhawk Buttons Replacement, Buttons: 1 단계, 이미지 1/1
    • Take the back cover off the phone and take the battery out.
  2. HTC Warhawk Buttons Replacement: 2 단계, 이미지 1/1
    • Take a SL#2.5 screwdriver and pop the black piece off shown here
  3. HTC Warhawk Buttons Replacement: 3 단계, 이미지 1/1
    • Take a T5 screwdriver and unscrew the two screws seen here
  4. HTC Warhawk Buttons Replacement: 4 단계, 이미지 1/1
    • Unscrew the two screws on the back of the phone with a T5 screwdriver
  5. HTC Warhawk Buttons Replacement: 5 단계, 이미지 1/2 HTC Warhawk Buttons Replacement: 5 단계, 이미지 2/2
    • Take the SL#2.5 screwdriver and pry off the back cover
    • The phone should now look like the second picture
  6. HTC Warhawk Buttons Replacement: 6 단계, 이미지 1/1
    • Take the SL#2.5 screwdriver and lift up the white connector at the top right corner of the phone on the side with the circuit board
  7. HTC Warhawk Buttons Replacement: 7 단계, 이미지 1/2 HTC Warhawk Buttons Replacement: 7 단계, 이미지 2/2
    • Next lift up the camera lens from the board.
    • It should now look like the second picture
    • Then lift up the circuit circled in red on the second picture
  8. HTC Warhawk Buttons Replacement: 8 단계, 이미지 1/2 HTC Warhawk Buttons Replacement: 8 단계, 이미지 2/2
    • Take the SL#2.5 screwdriver and pry off the volume buttons on the side of the phone
    • The circuit board should now be detached from the LCD part of the phone
  9. HTC Warhawk Buttons Replacement: 9 단계, 이미지 1/1
    • Next take the SL#2.5 screwdriver and pry the buttons off the phone and replace with the new ones
결론
Caitlin Bruce
회원 가입일: 10/04/11
23 평판
안내서 1개 작성함
UW Stout, Team 5-3, Zhou Fall 2011 UW Stout, Team 5-3, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S5G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 766
