소개
If you about to sell your phone and you want to wipe your personal data, or if your phone affected with virus or you want to delete the forgotten screen password, pattern lock you have to do a hard reset.
The factory Rest will remove your primary Microsoft account and you may lose data if it has not been synced. Be sure to back up any data and files you want to keep before you do a factory reset.
동영상 개요
Switch off the phone.
Press and hold the Volume Down button and connect the charger.
Hold the Volume Down button until you see an exclamation mark.
Press the buttons in sequence:
> VOLUME UP
> VOLUME DOWN
> POWER
> VOLUME DOWN.
다른 12명이 해당 안내서를 완성하였습니다.
댓글 5개
sa na pas marcher pourquoi
sa na pas marcher pourqoui
I have a HTC Windows phone 8S, its stuck in a restart cycle, it looks as though it is going to factory reset but it is stuck in a repeat cycle like a broken record. I keep trying to reset it! Help me please. Discover the truth and fix this record gone array. (array?)
