소개
How to replace the battery on HTC 8S.
필요한 것
동영상 개요
Switch off the phone.
Remove the SIM / memory card cover.
Remove any SIM and memory cards.
Use screwdriver torx T5 and unscrew the two screws at the bottom of the battery / back cover.
Use a Phillips #0 screwdriver and remove the 4x silver screws.
With a plastic tool carefully separate the battery from the logic board.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
