주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC Wizard 100 Screen Replacement
필요한 것
  1. HTC Wizard 100 Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 HTC Wizard 100 Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Power the phone off.
    • Use your thumb to gently press downward and away from the camera to remove the battery cover.
  2. HTC Wizard 100 Screen Replacement: 2 단계, 이미지 2개 중 1개 HTC Wizard 100 Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Pull on the plastic tab to release the battery.
  3. HTC Wizard 100 Screen Replacement, Back Case: 3 단계, 이미지 2개 중 1개 HTC Wizard 100 Screen Replacement, Back Case: 3 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to remove the camera cover.
    • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
    • Lift the camera cover off of the phone.
  4. HTC Wizard 100 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the stylus from the phone.
    • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
    • One of the screws might be under a sticker, which will void your warranty.
  5. HTC Wizard 100 Screen Replacement: 5 단계, 이미지 3개 중 1개 HTC Wizard 100 Screen Replacement: 5 단계, 이미지 3개 중 2개 HTC Wizard 100 Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
    • If your phone contains a memory card, you may want to remove it before proceeding with this step.
    • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
    • Lift the back case off completely.
    • The speakers might be dangling and unsecured.
  6. HTC Wizard 100 Screen Replacement, Speakers: 6 단계, 이미지 2개 중 1개 HTC Wizard 100 Screen Replacement, Speakers: 6 단계, 이미지 2개 중 2개
    • Grip the speaker connector with your thumb and finger and gently pull up.
    • Repeat for 2nd speaker.
  7. HTC Wizard 100 Screen Replacement, Camera: 7 단계, 이미지 1개 중 1개
    • Locate the camera and pry off with the plastic opening tool or spudger.
  8. HTC Wizard 100 Screen Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
    • Remove the 3.4 mm black screw with the Phillips #000 screwdriver.
  9. HTC Wizard 100 Screen Replacement: 9 단계, 이미지 2개 중 1개 HTC Wizard 100 Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the plastic tape to reveal the connector.
    • Use your finger or plastic opening tool to flip the connector and release the cable.
  10. HTC Wizard 100 Screen Replacement: 10 단계, 이미지 2개 중 1개 HTC Wizard 100 Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to carefully lift the motherboard off one corner at a time.
    • Lift the motherboard slowly away from the keyboard because there is a cable attached to bottom of the motherboard.
    • If the motherboard is not easily removed by pulling, then lift one side of the motherboard until you can see the attached cable. Then use the plastic opening tool to detach the cable from the motherboard.
  11. HTC Wizard 100 Screen Replacement, Screen: 11 단계, 이미지 2개 중 1개 HTC Wizard 100 Screen Replacement, Screen: 11 단계, 이미지 2개 중 2개
    • Using the Phillips Screwdriver #000 remove the four 3.3 mm screws.
    • Carefully lift the keyboard from the plastic plate by allowing the ribbon cable to slip through the opening of the plastic plate.
  12. HTC Wizard 100 Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Use the Phillips Screwdriver #000 to remove the four 3.8 mm screws from the back of the screen.
  13. HTC Wizard 100 Screen Replacement: 13 단계, 이미지 3개 중 1개 HTC Wizard 100 Screen Replacement: 13 단계, 이미지 3개 중 2개 HTC Wizard 100 Screen Replacement: 13 단계, 이미지 3개 중 3개
    • Insert the spudger between the panel and the case.
    • Gently pry off the panel by rotating or wiggling the spudger back and forth.
    • Lift the panel off while allowing the ribbon to slip through the opening.
  14. HTC Wizard 100 Screen Replacement: 14 단계, 이미지 3개 중 1개 HTC Wizard 100 Screen Replacement: 14 단계, 이미지 3개 중 2개 HTC Wizard 100 Screen Replacement: 14 단계, 이미지 3개 중 3개
    • Remove the four 2.9 mm screws with the Phillips Screwdriver #000.
    • Use your fingers to separate the screen assembly from the front panel.
  15. HTC Wizard 100 Screen Replacement: 15 단계, 이미지 2개 중 1개 HTC Wizard 100 Screen Replacement: 15 단계, 이미지 2개 중 2개
    • Insert the spudger between the green panel and the screen itself.
    • Gently wiggle the spudger to pry them apart.
  16. HTC Wizard 100 Screen Replacement: 16 단계, 이미지 3개 중 1개 HTC Wizard 100 Screen Replacement: 16 단계, 이미지 3개 중 2개 HTC Wizard 100 Screen Replacement: 16 단계, 이미지 3개 중 3개
    • Remove the tape.
    • Locate the connecting ribbon.
    • Using the spudger or your thumb and finger, flip the switch up and disconnect the ribbon.
    • Lift off the panel from the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Taylor Stone
회원 가입일: 10/06/11
45 평판
안내서 2개를 작성함
Cal Poly, Team 20-28, Maness Fall 2011 Cal Poly, Team 20-28, Maness Fall 2011 회원
CPSU-MANESS-F11S20G28
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 77
전체 시간: 1,289
