이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Power the phone off.
Use your thumb to gently press downward and away from the camera to remove the battery cover.
Use a plastic opening tool to remove the camera cover.
Lift the camera cover off of the phone.
Remove the stylus from the phone.
Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
Lift the back case off completely.
Grip the speaker connector with your thumb and finger and gently pull up.
Repeat for 2nd speaker.
