주요 콘텐츠로 건너뛰기
HTC Wizard 200 Receiver Replacement
필요한 것
  1. HTC Wizard 200 Receiver Replacement, Battery: 1 단계, 이미지 1/2 HTC Wizard 200 Receiver Replacement, Battery: 1 단계, 이미지 2/2
    • To expose the battery, remove the outer case with your fingernail.
    • Remove the battery by pulling the black tab.
  2. HTC Wizard 200 Receiver Replacement, Back Panel: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Spudger
    $3.99
    구매
    • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
  3. HTC Wizard 200 Receiver Replacement: 3 단계, 이미지 1/2 HTC Wizard 200 Receiver Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Spudger
    $3.99
    구매
    • Work the spudger around the edges of the camera cover until it comes off.
  4. HTC Wizard 200 Receiver Replacement: 4 단계, 이미지 1/2 HTC Wizard 200 Receiver Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    T5 Torx Screwdriver
    $5.49
    구매
    • Remove the four 6 mm screws with the T5 Torx screwdriver.
    • One of the screws is under the "void" sticker.
  5. HTC Wizard 200 Receiver Replacement: 5 단계, 이미지 1/3 HTC Wizard 200 Receiver Replacement: 5 단계, 이미지 2/3 HTC Wizard 200 Receiver Replacement: 5 단계, 이미지 3/3
    • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
    • Work the tool around the edges until all the clips release.
  6. HTC Wizard 200 Receiver Replacement: 6 단계, 이미지 1/2 HTC Wizard 200 Receiver Replacement: 6 단계, 이미지 2/2
    • Once all the clips are open, remove the inner panel from the phone.
  7. HTC Wizard 200 Receiver Replacement, Motherboard: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Spudger
    $3.99
    구매
    • Use the spudger to pry the camera off.
  8. HTC Wizard 200 Receiver Replacement: 8 단계, 이미지 1/2 HTC Wizard 200 Receiver Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers, flip the connector latch away from the motherboard.
    • Detach the flexible connection from under the connector latch.
  9. HTC Wizard 200 Receiver Replacement: 9 단계, 이미지 1/1
    • Slide the keyboard into the open position.
  10. HTC Wizard 200 Receiver Replacement: 10 단계, 이미지 1/2 HTC Wizard 200 Receiver Replacement: 10 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Spudger
    $3.99
    구매
    • Lift the motherboard out of the case using the spudger.
    • Expose the underside of the motherboard using your hands.
  11. HTC Wizard 200 Receiver Replacement: 11 단계, 이미지 1/2 HTC Wizard 200 Receiver Replacement: 11 단계, 이미지 2/2
    • Remove the flexible connection from the motherboard.
    • Caution: Removing the connection too fast may cause damage to the connection and cables.
  12. HTC Wizard 200 Receiver Replacement, Keyboard Slider: 12 단계, 이미지 1/3 HTC Wizard 200 Receiver Replacement, Keyboard Slider: 12 단계, 이미지 2/3 HTC Wizard 200 Receiver Replacement, Keyboard Slider: 12 단계, 이미지 3/3
    이 단계에 사용된 도구:
    T5 Torx Screwdriver
    $5.49
    구매
    • Remove the four 5mm screws with the T5 Torx screwdriver.
    • Remove the keyboard slider from the main body.
  13. HTC Wizard 200 Receiver Replacement, Screen Cover: 13 단계, 이미지 1/2 HTC Wizard 200 Receiver Replacement, Screen Cover: 13 단계, 이미지 2/2
    • Use the T5 Torx screwdriver to remove four 5mm screws that secure the back of the screen casing.
  14. HTC Wizard 200 Receiver Replacement: 14 단계, 이미지 1/2 HTC Wizard 200 Receiver Replacement: 14 단계, 이미지 2/2
    • Insert the plastic opening tool between the front panel and the rear panel and pry open to reach the screen.
  15. HTC Wizard 200 Receiver Replacement: 15 단계, 이미지 1/2 HTC Wizard 200 Receiver Replacement: 15 단계, 이미지 2/2
    • Once the rear panel is loose, lift it off of the front panel.
    • The flexible connection will pop loose.
  16. HTC Wizard 200 Receiver Replacement: 16 단계, 이미지 1/1
    • Device rotated 90 degrees CCW.
    • Remove the yellow anti-static tape.
  17. HTC Wizard 200 Receiver Replacement: 17 단계, 이미지 1/2 HTC Wizard 200 Receiver Replacement: 17 단계, 이미지 2/2
    • Unscrew the two 3mm phillips #0 screws from the bottom of the device that secure the rigid flex board to the screen panel.
  18. HTC Wizard 200 Receiver Replacement: 18 단계, 이미지 1/1
    • Device rotated 180 degrees CW.
    • Unscrew the two 3mm phillips #0 screws from the top of the device that secure the rigid flex board to the screen panel.
  19. HTC Wizard 200 Receiver Replacement: 19 단계, 이미지 1/1
    • Unhinge the flexible connection and use the tweezers to disconnect.
  20. HTC Wizard 200 Receiver Replacement: 20 단계, 이미지 1/1
    • Now that the rigid flex board is loose, remove it from the screen.
  21. HTC Wizard 200 Receiver Replacement, LCD Screen: 21 단계, 이미지 1/2 HTC Wizard 200 Receiver Replacement, LCD Screen: 21 단계, 이미지 2/2
    • Simply pull out the loose screen.
  22. HTC Wizard 200 Receiver Replacement, Receiver: 22 단계, 이미지 1/2 HTC Wizard 200 Receiver Replacement, Receiver: 22 단계, 이미지 2/2
    • Use the tweezers to take out the receiver.
결론
Kyle Champ
회원 가입일: 10/03/11
225 평판
안내서 12개 작성하였습니다
Cal Poly, Team 20-27, Maness Fall 2011 Cal Poly, Team 20-27, Maness Fall 2011 회원
CPSU-MANESS-F11S20G27
4 회원들
안내서 24개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 11
전체 시간: 897
