소개
Takes you through the steps to install the vibrator.
필요한 것
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
이 단계에 사용된 도구:T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
거의 끝나갑니다!
결론
