주요 콘텐츠로 건너뛰기
HUAWEI HONOR 5X Charging Port Replacement
필요한 것
  1. HUAWEI HONOR 5X Charging Port Replacement, HUAWEI HONOR 5X Disassembly: 1 단계, 이미지 1/1
    • Turn off your cell phone before disassembling.
  2. HUAWEI HONOR 5X Charging Port Replacement: 2 단계, 이미지 1/1
    • Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
  3. HUAWEI HONOR 5X Charging Port Replacement: 3 단계, 이미지 1/2 HUAWEI HONOR 5X Charging Port Replacement: 3 단계, 이미지 2/2
    • Use the Sim card ejection tool to remove both the sim card trays.
  4. HUAWEI HONOR 5X Charging Port Replacement: 4 단계, 이미지 1/1
    • To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
  5. HUAWEI HONOR 5X Charging Port Replacement: 5 단계, 이미지 1/2 HUAWEI HONOR 5X Charging Port Replacement: 5 단계, 이미지 2/2
    • Pry off the back with a plastic opening tool.
  6. HUAWEI HONOR 5X Charging Port Replacement, Charging Port: 6 단계, 이미지 1/2 HUAWEI HONOR 5X Charging Port Replacement, Charging Port: 6 단계, 이미지 2/2
    • Remove the six 1.5mm Phillips #000 screws from the bottom of the phone.
  7. HUAWEI HONOR 5X Charging Port Replacement: 7 단계, 이미지 1/2 HUAWEI HONOR 5X Charging Port Replacement: 7 단계, 이미지 2/2
    • Use a plastic opening tool to disconnect the white and black antenna cables from the daughterboard.
  8. HUAWEI HONOR 5X Charging Port Replacement: 8 단계, 이미지 1/1
    • Remove the daughterboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Klara Asllani
회원 가입일: 01/25/18
788 평판
안내서 5개 작성하였습니다
USF Tampa, Team S7-G6, Passmore Spring 2018 USF Tampa, Team S7-G6, Passmore Spring 2018 회원
USFT-PASSMORE-S18S7G6
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 1,680
