주요 콘텐츠로 건너뛰기
HUAWEI HONOR 5X Vibration Motor Replacement
필요한 것
  1. HUAWEI HONOR 5X Vibration Motor Replacement, HUAWEI HONOR 5X Disassembly: 1 단계, 이미지 1/1
    • Turn off your cell phone before disassembling.
  2. HUAWEI HONOR 5X Vibration Motor Replacement: 2 단계, 이미지 1/1
    • Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
  3. HUAWEI HONOR 5X Vibration Motor Replacement: 3 단계, 이미지 1/2 HUAWEI HONOR 5X Vibration Motor Replacement: 3 단계, 이미지 2/2
    • Use the Sim card ejection tool to remove both the sim card trays.
  4. HUAWEI HONOR 5X Vibration Motor Replacement: 4 단계, 이미지 1/1
    • To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
  5. HUAWEI HONOR 5X Vibration Motor Replacement: 5 단계, 이미지 1/2 HUAWEI HONOR 5X Vibration Motor Replacement: 5 단계, 이미지 2/2
    • Pry off the back with a plastic opening tool.
  6. HUAWEI HONOR 5X Vibration Motor Replacement, Motherboard: 6 단계, 이미지 1/2 HUAWEI HONOR 5X Vibration Motor Replacement, Motherboard: 6 단계, 이미지 2/2
    • Remove the five 1.5mm Phillips #000 screws from the motherboard.
  7. HUAWEI HONOR 5X Vibration Motor Replacement: 7 단계, 이미지 1/2 HUAWEI HONOR 5X Vibration Motor Replacement: 7 단계, 이미지 2/2
    • Use a plastic opening tool to pry up and disconnect the display cable from the motherboard.
    • Use tweezers to disconnect the white coax cable.
    • Use tweezers to disconnect the power and volume cable.
  8. HUAWEI HONOR 5X Vibration Motor Replacement: 8 단계, 이미지 1/3 HUAWEI HONOR 5X Vibration Motor Replacement: 8 단계, 이미지 2/3 HUAWEI HONOR 5X Vibration Motor Replacement: 8 단계, 이미지 3/3
    • Remove the motherboard.
  9. HUAWEI HONOR 5X Vibration Motor Replacement, Vibration Motor: 9 단계, 이미지 1/2 HUAWEI HONOR 5X Vibration Motor Replacement, Vibration Motor: 9 단계, 이미지 2/2
    • Using the metal spudger, pry the adhered vibration monitor to remove.
    • Using the metal spudger may damage the internal components of your device, so please use the plastic spudger or opening tool instead.
결론
Coffel
회원 가입일: 02/13/20
73 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 196
