주요 콘텐츠로 건너뛰기
HVAC Filter Replacement
필요한 것
  1. HVAC Filter Replacement, Filter: 1 단계, 이미지 1개 중 1개
    • Observe your air conditioning vent. If the filter appears to be dirty or damaged, then it is time to change it.
  2. HVAC Filter Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the screws on the vent cover. There should be a minimum of 4 screws in each corner of the vent.
    • The screws in this vent are phillips hex head screws that are 1 3/4 in. long.
  3. HVAC Filter Replacement: 3 단계, 이미지 1개 중 1개
    • Grab a screwdriver with a hex head attachment to remove the screws. Grab the screwdriver and place it on the head of the screw. Twist in a counterclockwise motion until the screw is removed. Repeat for every screw.
  4. HVAC Filter Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the vent cover to access the ventilation filter.
  5. HVAC Filter Replacement: 5 단계, 이미지 1개 중 1개
    • Optional: Put on a latex glove on the hand that you will use to remove the filter.
  6. HVAC Filter Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the filter carefully.
    • Make sure to remove it slowly so that the dust does not come of it.
  7. HVAC Filter Replacement: 7 단계, 이미지 1개 중 1개
    • Dispose of the old filter in a waste bin.
  8. HVAC Filter Replacement: 8 단계, 이미지 1개 중 1개
    • Buy a Honeywell Air Filter from Home Depot and make sure to buy the filter with the correct dimensions.
    • The dimensions for filters will vary depending on the dimensions of the vent.
    • In this case, my vent was 14x25x1 and thus needed a filter with the same dimensions.
  9. HVAC Filter Replacement: 9 단계, 이미지 1개 중 1개
    • Place the new filter into the vent opening. Make sure that it is facing the right direction.
    • There will be an arrow on the side of the filter showing which way to place it.
  10. HVAC Filter Replacement: 10 단계, 이미지 1개 중 1개
    • Place vent cover.
  11. HVAC Filter Replacement: 11 단계, 이미지 1개 중 1개
    • Grab the same screws that were taken out at Step 3 and use them to secure the vent cover.
    • Place the screwdriver on the head of the screw and twist in a clockwise motion until screw is secure.
    • Repeat for every screw.
  12. HVAC Filter Replacement: 12 단계, 이미지 1개 중 1개
    • Turn on your air conditioner to make sure the filter does not move.
    • If the filter does not move, then you have successfully replaced the filter of your air conditioner.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Anthony Estevez
회원 가입일: 10/20/23
67 평판
안내서 1개를 작성함
CSU Los Angeles, Team 2-1, Briggs Fall 2023 CSU Los Angeles, Team 2-1, Briggs Fall 2023 회원
CSULA-BRIGGS-F23S2G1
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 34
전체 시간: 504
