이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
필요한 것
Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
Using a Phillips #1 Screwdriver, remove the screws located on the hair dryer handle.
Gently pull the button switchboard away from the hair dryer body.
Using a desoldering wick and a soldering iron, desolder the wires.
Refer to the following page for desoldering instructions: Soldering Skills
다른 한 분이 해당 안내서를 완성하였습니다.
