주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hair Dryer Electrical Brushes Replacement
필요한 것
  1. Hair Dryer Electrical Brushes Replacement, Electrical Brushes: 1 단계, 이미지 3개 중 1개 Hair Dryer Electrical Brushes Replacement, Electrical Brushes: 1 단계, 이미지 3개 중 2개 Hair Dryer Electrical Brushes Replacement, Electrical Brushes: 1 단계, 이미지 3개 중 3개
    • Make sure to unplug the device before beginning.
    • Rotate the stainless steel filter counterclockwise and pull upwards to remove it.
  2. Hair Dryer Electrical Brushes Replacement: 2 단계, 이미지 2개 중 1개 Hair Dryer Electrical Brushes Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove the two screws securing the back cover.
  3. Hair Dryer Electrical Brushes Replacement: 3 단계, 이미지 3개 중 1개 Hair Dryer Electrical Brushes Replacement: 3 단계, 이미지 3개 중 2개 Hair Dryer Electrical Brushes Replacement: 3 단계, 이미지 3개 중 3개
    • Lift off the back cover.
  4. Hair Dryer Electrical Brushes Replacement: 4 단계, 이미지 3개 중 1개 Hair Dryer Electrical Brushes Replacement: 4 단계, 이미지 3개 중 2개 Hair Dryer Electrical Brushes Replacement: 4 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove the two screws securing the dryer motor.
    • Remove the motor from its plastic housing.
  5. Hair Dryer Electrical Brushes Replacement: 5 단계, 이미지 3개 중 1개 Hair Dryer Electrical Brushes Replacement: 5 단계, 이미지 3개 중 2개 Hair Dryer Electrical Brushes Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew the small plastic cap on the side of the motor and lift out the spring.
    • Remove the carbon electrical brush.
    • Repeat for the cap on the other side of the motor.
  6. Hair Dryer Electrical Brushes Replacement: 6 단계, 이미지 3개 중 1개 Hair Dryer Electrical Brushes Replacement: 6 단계, 이미지 3개 중 2개 Hair Dryer Electrical Brushes Replacement: 6 단계, 이미지 3개 중 3개
    • Install the new carbon brushes, and screw the caps back on.
    • Make sure the spring beneath the cap is properly positioned before tightening,
  7. Hair Dryer Electrical Brushes Replacement: 7 단계, 이미지 3개 중 1개 Hair Dryer Electrical Brushes Replacement: 7 단계, 이미지 3개 중 2개 Hair Dryer Electrical Brushes Replacement: 7 단계, 이미지 3개 중 3개
    • Place the motor back into the housing.
    • Rotate the motor clockwise to screw it into place.
    • Refasten the two motor screws using a Phillips #1 screwdriver.
  8. Hair Dryer Electrical Brushes Replacement: 8 단계, 이미지 3개 중 1개 Hair Dryer Electrical Brushes Replacement: 8 단계, 이미지 3개 중 2개 Hair Dryer Electrical Brushes Replacement: 8 단계, 이미지 3개 중 3개
    • Place the white wires coming off the motor back in the slots.
    • Place the diode in the slots.
  9. Hair Dryer Electrical Brushes Replacement: 9 단계, 이미지 2개 중 1개 Hair Dryer Electrical Brushes Replacement: 9 단계, 이미지 2개 중 2개
    • Set the power cord back in its slot.
  10. Hair Dryer Electrical Brushes Replacement: 10 단계, 이미지 3개 중 1개 Hair Dryer Electrical Brushes Replacement: 10 단계, 이미지 3개 중 2개 Hair Dryer Electrical Brushes Replacement: 10 단계, 이미지 3개 중 3개
    • Reinstall the back cover.
  11. Hair Dryer Electrical Brushes Replacement: 11 단계, 이미지 3개 중 1개 Hair Dryer Electrical Brushes Replacement: 11 단계, 이미지 3개 중 2개 Hair Dryer Electrical Brushes Replacement: 11 단계, 이미지 3개 중 3개
    • Place the two screws back in place and tighten them with a Phillips #1 screwdriver.
결론
Enjoy your functional hair dryer!
작성자
1다른 기여자 명과 함께
Alejandra Medina
회원 가입일: 03/18/22
193 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 22
지난 30일: 86
전체 시간: 2,005
