이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
Detach the hair dryer grating from the body by gently twisting the grating from side to side.
Separate the hair dryer grating into the three pieces seen in the image.
Locate the screws on the handle and remove with a Phillips screwdriver.
After removing the plastic case, locate the fan towards the back of the hair dryer.
Remove the screw that is holding the fan to the motor using a Phillips screwdriver.
Remove the screws holding the motor to the casing using a Phillips screwdriver.
Isolate the fan from the rest of the dryer.
Remove the screws holding the motor in place. Replace with the new component.
Solder the wires to the motor. Refer to the soldering page below, which will help you replace this component.
다른 2명이 해당 안내서를 완성하였습니다.
