주요 콘텐츠로 건너뛰기
Hair Scrunchie Elastic Replacement
필요한 것
  1. Hair Scrunchie Elastic Replacement, Hair Scrunchie Elastic: 1 단계, 이미지 1/1
    • There are two seams that hold the fabric outer tube of the scrunchie together. The long seam runs along the entire circumference of the tube. The short seam goes around just one part of the tube.
  2. Hair Scrunchie Elastic Replacement: 2 단계, 이미지 1/2 Hair Scrunchie Elastic Replacement: 2 단계, 이미지 2/2
    • Locate the short seam and use the hem ripper to carefully cut through each stitch without damaging the fabric.
    • Do not cut through the stitches where the long seam intersect with he short seam.
  3. Hair Scrunchie Elastic Replacement: 3 단계, 이미지 1/1
    • Attach the elastic band to the end of a pencil with a piece of tape.
  4. Hair Scrunchie Elastic Replacement: 4 단계, 이미지 1/2 Hair Scrunchie Elastic Replacement: 4 단계, 이미지 2/2
    • Insert the pencil tip into one end of the fabric tube.
    • As you push the pencil through, scrunch the fabric together until the tip comes out the other side.
  5. Hair Scrunchie Elastic Replacement: 5 단계, 이미지 1/2 Hair Scrunchie Elastic Replacement: 5 단계, 이미지 2/2
    • Tie a secure knot with the newly replaced elastic.
  6. Hair Scrunchie Elastic Replacement: 6 단계, 이미지 1/1
    • Prepare your needle and thread by tying a knot at the end.
  7. Hair Scrunchie Elastic Replacement: 7 단계, 이미지 1/1
    • Insert the needle at the spot holding each end of the tube together.
  8. Hair Scrunchie Elastic Replacement: 8 단계, 이미지 1/3 Hair Scrunchie Elastic Replacement: 8 단계, 이미지 2/3 Hair Scrunchie Elastic Replacement: 8 단계, 이미지 3/3
    • Use the ladder stitch technique to sew each end of the tube back together.
    • Use this guide for assistance.
  9. Hair Scrunchie Elastic Replacement: 9 단계, 이미지 1/3 Hair Scrunchie Elastic Replacement: 9 단계, 이미지 2/3 Hair Scrunchie Elastic Replacement: 9 단계, 이미지 3/3
    • Tie a knot and use your finger to keep the knot close as close to the fabric as possible.
    • Repeat this process until the thread is secure.
  10. Hair Scrunchie Elastic Replacement: 10 단계, 이미지 1/1
    • Trim the thread as close to the knot as possible.
결론
This is a simple and effective way to replace the elastic so that you can continue to use the hair accessory.
다른 9명이 해당 안내서를 완성하였습니다.
Malena Hansen
회원 가입일: 10/24/18
239 평판
안내서 1개 작성함
UC Davis, Team S2-G2, Bender Fall 2018 UC Davis, Team S2-G2, Bender Fall 2018 회원
UCD-BENDER-F18S2G2
3 회원들
안내서 2개 작성하였습니다
댓글 한 개
Amazing
Been looking for a way to fix my scrunchie
Thanks!
Mollytheduck1 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 22
30일 전: 111
전체 시간: 23,842
