주요 콘텐츠로 건너뛰기
Hamilton Beach Power Cord Replacement
필요한 것
  1. Hamilton Beach  Power Cord Replacement, Motor: 1 단계, 이미지 1/3 Hamilton Beach  Power Cord Replacement, Motor: 1 단계, 이미지 2/3 Hamilton Beach  Power Cord Replacement, Motor: 1 단계, 이미지 3/3
    • Flip the handle on its side. Remove five 3.8 mm Philips #2 screws shown and set aside them aside.
  2. Hamilton Beach  Power Cord Replacement: 2 단계, 이미지 1/3 Hamilton Beach  Power Cord Replacement: 2 단계, 이미지 2/3 Hamilton Beach  Power Cord Replacement: 2 단계, 이미지 3/3
    • Remove the four 8.6 mm Philips #2 screws securing the motor mount and place them aside.
  3. Hamilton Beach  Power Cord Replacement: 3 단계, 이미지 1/3 Hamilton Beach  Power Cord Replacement: 3 단계, 이미지 2/3 Hamilton Beach  Power Cord Replacement: 3 단계, 이미지 3/3
    • Carefully pull the motor block out of the case.
    • Collect the two spring located on top of the white beater gears. The springs are held in place with compression, and may fall into the case when the motor is moved.
    • Handle the wires with care to ensure you do not break any of them.
  4. Hamilton Beach  Power Cord Replacement: 4 단계, 이미지 1/3 Hamilton Beach  Power Cord Replacement: 4 단계, 이미지 2/3 Hamilton Beach  Power Cord Replacement: 4 단계, 이미지 3/3
    • Desolder the six wires connected to the motor using this guide.
    • Make sure to note colors when you disconnect them and remember where to reconnect them later.
  5. Hamilton Beach  Power Cord Replacement: 5 단계, 이미지 1/2 Hamilton Beach  Power Cord Replacement: 5 단계, 이미지 2/2
    • Once disconnected, the motor will slide out easily.
  6. Hamilton Beach  Power Cord Replacement, Speed Level: 6 단계, 이미지 1/3 Hamilton Beach  Power Cord Replacement, Speed Level: 6 단계, 이미지 2/3 Hamilton Beach  Power Cord Replacement, Speed Level: 6 단계, 이미지 3/3
    • Remove the seven 5.6 mm Philips #2 screws that attach the motor casing to the mixer handle and set them aside.
  7. Hamilton Beach  Power Cord Replacement: 7 단계, 이미지 1/3 Hamilton Beach  Power Cord Replacement: 7 단계, 이미지 2/3 Hamilton Beach  Power Cord Replacement: 7 단계, 이미지 3/3
    • Use a plastic opening tool to take off the handle's cap by loosening both ends and then sliding the tool to the middle of the handle.
  8. Hamilton Beach  Power Cord Replacement: 8 단계, 이미지 1/2 Hamilton Beach  Power Cord Replacement: 8 단계, 이미지 2/2
    • Remove the handle's cap carefully.
    • Watch out for the quick burst button, it likes to run away.
  9. Hamilton Beach  Power Cord Replacement: 9 단계, 이미지 1/3 Hamilton Beach  Power Cord Replacement: 9 단계, 이미지 2/3 Hamilton Beach  Power Cord Replacement: 9 단계, 이미지 3/3
    • Slide the speed switch forward and lift upward off of the handle.
  10. Hamilton Beach  Power Cord Replacement: 10 단계, 이미지 1/2 Hamilton Beach  Power Cord Replacement: 10 단계, 이미지 2/2
    • Remove speed level from the inside of the case by applying light pressure toward you.
    • Do not pull on the wires to remove the speed level.
  11. Hamilton Beach  Power Cord Replacement: 11 단계, 이미지 1/3 Hamilton Beach  Power Cord Replacement: 11 단계, 이미지 2/3 Hamilton Beach  Power Cord Replacement: 11 단계, 이미지 3/3
    • Remove the beater release button from speed level by removing the two 1.3 mm Philips #2 screws.
    • Replace the speed level assembly.
  12. Hamilton Beach  Power Cord Replacement, Power Cord: 12 단계, 이미지 1/3 Hamilton Beach  Power Cord Replacement, Power Cord: 12 단계, 이미지 2/3 Hamilton Beach  Power Cord Replacement, Power Cord: 12 단계, 이미지 3/3
    • Liftback end of the handle up from motor casing.
    • Pull back to detach fully from the stainless steel.
  13. Hamilton Beach  Power Cord Replacement: 13 단계, 이미지 1/3 Hamilton Beach  Power Cord Replacement: 13 단계, 이미지 2/3 Hamilton Beach  Power Cord Replacement: 13 단계, 이미지 3/3
    • Remove the three 7.8 mm Philips #2 screws holding the power cord in place.
  14. Hamilton Beach  Power Cord Replacement: 14 단계, 이미지 1/3 Hamilton Beach  Power Cord Replacement: 14 단계, 이미지 2/3 Hamilton Beach  Power Cord Replacement: 14 단계, 이미지 3/3
    • Cut zip tie holding the power cable together using handheld wire cutters.
  15. Hamilton Beach  Power Cord Replacement: 15 단계, 이미지 1/3 Hamilton Beach  Power Cord Replacement: 15 단계, 이미지 2/3 Hamilton Beach  Power Cord Replacement: 15 단계, 이미지 3/3
    • Untie the black lead's knot.
    • Cut both wires with handheld wire cutters.
    • Follow this guide to solder new power cord wires in.
결론
Gwen Davis
회원 가입일: 03/24/16
519 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 7-3, Catania Spring 2016 UMass Dartmouth, Team 7-3, Catania Spring 2016 회원
UMASSD-CATANIA-S16S7G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 1,473
